67 RS Ball Joint - Team Camaro Tech
 4Likes
post #1 of 16 (permalink) Old Aug 6th, 17, 11:03 AM Thread Starter
Jonathan
67 RS Ball Joint
After I rebuilt my suspension the joint has always looked like this. Seems like the rubber should sit flush. Both sides are like this.
Red6a1 is offline
post #2 of 16 (permalink) Old Aug 6th, 17, 02:12 PM Thread Starter
Jonathan
Re: 67 RS Ball Joint
This picture is on a jack stand. Once the wheel is on, it does lower some, but seems like it should be lower.
Red6a1 is offline
post #3 of 16 (permalink) Old Aug 6th, 17, 04:44 PM
David Pozzi
davidpozzi's Avatar
There should be a rubber droop stop that is held by a round hole in the upper A arm. Yours is missing or broken or it wouldn't droop so low
davidpozzi is offline
post #4 of 16 (permalink) Old Aug 7th, 17, 06:23 AM Thread Starter
Jonathan
Here the picture with the weight on the wheel.
Red6a1 is offline
post #5 of 16 (permalink) Old Aug 7th, 17, 06:33 AM
Post a pic of the car on the ground at ride height.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #6 of 16 (permalink) Old Aug 7th, 17, 05:00 PM Thread Starter
Jonathan
The last picture was with wheel on and tire on ground. Original 14" wheels.
Red6a1 is offline
post #7 of 16 (permalink) Old Aug 7th, 17, 05:12 PM Thread Starter
Jonathan
Can someone post a picture on theirs at ride height?
Red6a1 is offline
post #8 of 16 (permalink) Old Aug 7th, 17, 05:12 PM
George
As per previous posting, we need a picture from the side of the car showing its stance. It looks as though the spring may not be in its' pocket, which would make the car sit high, and not allow the control arms to get to the proper location. JM2C
dhutton likes this.
67 RS Ragtop is offline
post #9 of 16 (permalink) Old Aug 7th, 17, 05:16 PM
I meant the side of the car. It looks like you might have quite a high ride height...
Did you use "heavy duty" springs when you rebuilt the front end?
post #10 of 16 (permalink) Old Aug 8th, 17, 04:48 PM Thread Starter
Jonathan
Will this view work?
Red6a1 is offline
post #11 of 16 (permalink) Old Aug 8th, 17, 05:17 PM
Yep. Your high ride height is causing that ball joint angle imho. Rear is even higher? Fix your ride height through new springs and you should be ok assuming the current springs are sitting in the pocket correctly.
allanjs likes this.
post #12 of 16 (permalink) Old Aug 8th, 17, 08:50 PM Thread Starter
Jonathan
The rear has new mono springs and shocks. The front has new springs as well. The original springs in the front were upgraded to the HD version as I planned on one day installing AC. I already upgraded to the bigger radiator as well.
Red6a1 is offline
post #13 of 16 (permalink) Old Aug 8th, 17, 10:09 PM
George
One other question - did you tighten down the fasteners (spring eye bolts, shackles, etc.) while the weight was on the car ? If not, loosen everything up, then re tighten with the vehicles weight on the suspension components.
ctcz28 likes this.
post #14 of 16 (permalink) Old Aug 9th, 17, 05:35 AM Thread Starter
Jonathan
I used a jack to put pressure on the axle when I tightened them up. I will give your suggestion a try. Seems like the car is riding really high and huge wheel well area. Reminds me of Chevy's 2500 series trucks. Tiny tires on a big truck.
Red6a1 is offline
post #15 of 16 (permalink) Old Aug 9th, 17, 06:10 AM
Aftermarket AC does not require HD springs. I suggest you swap them out.
ctcz28 likes this.
