valve in power steering pump - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 13th, 17, 09:43 AM Thread Starter
thewebb1's Avatar
On my 67 vert I've got a early GM steering pump (year unknown) hooked up to an 85 IROC steering box and understand the valve has to be changed to a valve that will allow higher pressure i.e. 1200-1400psi. The pump I was told may have been upgraded but it's not for sure. Is there a way to tell which valve I have?
Any help is appreciated.
67 Camaro RS350SS (already restored) 68Convertible(future project)
68 Coupe(restoring)On hold
Gave to friend.
67 Convertible (restoring)
67 Coupe(parts car for now)
72 Chevelle Malibu
2-69 Jaguar xke roadsters (appeasing the wife)
thewebb1 is offline
post #2 of 4 (permalink) Old Aug 13th, 17, 03:25 PM
David Pozzi
davidpozzi's Avatar
Re: valve in power steering pump
Here's my web page on pump mods. You can check your orifice against the specs on my page. Also look at the spacers on the pressure valve behind the "nut". Late model pumps have the same thing but the nut is held in place by Loctite instead of washers. To get near max pressure you want only one or no spacers on there.
Camaro steering
davidpozzi is offline
post #3 of 4 (permalink) Old Aug 14th, 17, 08:19 PM Thread Starter
thewebb1's Avatar
Thanks David, that's exactly what I was looking for.
I'll read the complete article and see which set-up I have and modify accordingly.
Thanks again,
Gave to friend.
72 Chevelle Malibu
thewebb1 is offline
post #4 of 4 (permalink) Old Aug 15th, 17, 09:41 PM
David Pozzi
davidpozzi's Avatar
You're welcome.
