Cheap (Chinese?) tubular Upper control arms - Team Camaro Tech
 2Likes
post #1 of 23 (permalink) Old Aug 14th, 17, 05:20 AM Thread Starter
This isn't meant to become a why you should buy American thread. I am only relaying my experience with the inexpensive tubular control arms you can buy on eBay. Most think these are cheap Chinese knock offs. They very well could be or are, but there was no indication of country of origin that I could see.
The lower control arm went on as easy as putting on any lower control arm. There is that bolt that you can't see and worry you will drop it or your socket into the frame. I did manage to get the bolt in and torqued properly. I also managed to drop my socket and extension into the frame. I got lucky and with the help of a wire coat hangar, I managed to retrieve both.
The upper control arm, which should be the easier of the two to install brought me to a stand still. The cams that slide over the studs did not fit. Well seven of the eight cam would not fit. The one in the picture with the blue tape, is the only one that fit.
I have contacted the seller, who immediately offered a $20 refund and to see if I can fix it myself. I replied that i haven't a clue how to fix this, and by sending me cams that fit, it would be cheaper to ship than the $20. Ill keep everyone posted on how it turns out.
In the meantime, I have been thinking of how to make them work. I first tried to spin them on, sort of threading them on, but that won't work and to be honest I worried about damaging the threads on the studs. Next I thought about drilling them out, but cannot determine the correct drill bit size, or even if this should be done. A 7/16 drill bit is too large, and everything else is too small. Any thoughts on whether or not this should even be done?
Thanks,
BH
BigHog is offline
post #2 of 23 (permalink) Old Aug 14th, 17, 05:25 AM
Re: Cheap (Chinese?) tubular Upper control arms
Try a number drill set to find the correct size and drill all to the same size as the one that fits.
1969 Camaro LM1
chicoman is offline
post #3 of 23 (permalink) Old Aug 14th, 17, 05:53 AM Thread Starter
Copy that, thank you. I assume this means you think it would be fine to drill the cams? I was worried about the integrity of the cams from drilling, since this impacts alignment.
BigHog is offline
post #4 of 23 (permalink) Old Aug 14th, 17, 06:45 AM
Chris
Yep, sounds like Chinese tolerances - close but no cigar. Like my Harbor Freight impact sockets that are close, but won't fit over the bolt/nut, but the same size Craftsman sockets do fit perfectly. As a result, can't use them very often.
X2 on the numbered drill.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #5 of 23 (permalink) Old Aug 14th, 17, 06:58 AM
Bruce
What real advantage are the aftermarket tubular arms compared to properly poly built factory arms with a proper alignment. Perhaps if your are driving on a road course it may be somewhat better. Is the cost worth it?
The Camaro Guy is offline
post #6 of 23 (permalink) Old Aug 14th, 17, 07:04 AM Thread Starter
For me after a good bit of reading and research it seemed like the way to go. If I were to do it again, I would just have the OEM ones refitted. This isn't meant to be a debate on whether or not to go to tubular control arms, just my experience with the inexpensive ones.
BigHog is offline
post #7 of 23 (permalink) Old Aug 14th, 17, 07:13 AM
Vega$69's Avatar
Easy enough to ream the cams
Vega$69 is offline
post #8 of 23 (permalink) Old Aug 14th, 17, 07:17 AM Thread Starter
So no concerns of the integrity of the cam, once reamed?
Thanks,
BigHog is offline
post #9 of 23 (permalink) Old Aug 14th, 17, 07:35 AM
Usually increased caster and improved ball joint angles at lowered ride heights. Both are positives....
Moonpie likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #10 of 23 (permalink) Old Aug 14th, 17, 10:17 AM
Jeremy
Thought I would share a problem I ran into with my eBay control arms. Both the upper and lower ball joints failed after driving the car about 200 miles. I replace them with moog ball joints and they are great now.
Jeremy
1967 rs, 355 sbc, Pontiac 867 heads, Crower rockers, Isky roller cam, FiTech Power Adder 600, Hurst Drivelines T-56 Magnum, RAM clutch, 4.10 posi, Vision 18" wheels
wireboy355 is offline
post #11 of 23 (permalink) Old Aug 14th, 17, 11:50 AM
Vega$69's Avatar
I'm also working on a guys 68 right now that has the Chinese tubular a arms
The ARMs themselves look good enough however the ball joints are terrible and will have to be replaced before the car is driven
Vega$69 is offline
post #12 of 23 (permalink) Old Aug 14th, 17, 11:52 AM
Those parts are called caster slugs - they's used a lot in race cars to adjust caster. You may be able to source replacements online, but you'll have to make sure the overall size matches your control arm recess. I've heard (no personal experience) that the slugs that come with the arms can be brittle, so replacement may kill two birds with one stone.
Mike - '68 Camaro with lots of stuff done to it.
Mkelcy is offline
post #13 of 23 (permalink) Old Aug 14th, 17, 01:54 PM
X 2...heard of a few failures, so no a bad idea.
68 Camaro~LSx ~all motor
post #14 of 23 (permalink) Old Aug 14th, 17, 02:00 PM
Did mine a few weeks ago... I chose not to go with the generic eBay ones, went with Helix which are CAD designed here in the USA but yes... like so much else, made in China. Helix also has tech support here in the states. More money than the eBays but less than the premium made in the USA ones.
Replaced the upper/lower BJs with ProForged and used the Tall Spec uppers. The arms went in just fine, alignment went fine, but bc of my Hotchkis 2" drop springs I had to add .750" Global West GM spec coil seats to get her back to where I wanted her height wise. Also did all the tie rod stuff with ProForged. Also added a JGC steering box.
Couldn't be happier, car is far less edgy on the highway and curves... steering is 150% better.
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #15 of 23 (permalink) Old Aug 14th, 17, 05:05 PM
Nick
Rarerat's Avatar
I tried a set of those ebay control arms on the Blue 67 I built last year. I pulled them & went back to stock arms after only about 200 miles. The car drove horrible no matter how I aligned the front end and I didn't care for the 2.5" drop they caused. In all fairness I guess I should mention, I'm not a trained alignment tech but I have allways done my own alignments and never had any problems before. Once I pulled them & went back to factory control arms the car drove the way it should. I have heard good things about those arms from different people so maybe I just got a bad set??? Anyway, thats just my experience with them, good luck..
Rarerat is offline
