69 steering box interference with headers - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 16th, 17, 11:54 AM Thread Starter
Apprentice
Ken
My 69 has a 454 w/ headers which are 2" primaries and there is no clearance between the factory power steering box and the headers. I have dimpled the headers and shimmed the motor mount to raise that side of the block but still not enough room. What is the best/most economical way to fix this?
Thanks Team Camaro, Ken.
chebbygodby is offline
post #2 of 9 (permalink) Old Aug 16th, 17, 11:59 AM
Matt
Re: 69 steering box interference with headers
We will need a little more information in order to help you out. What brand headers? Model #?, Is this a big block conversion or a factory big block car? Do you have the correct big block frames stands and transmission cross member? Automatic or manual transmission?
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #3 of 9 (permalink) Old Aug 16th, 17, 12:21 PM Thread Starter
Apprentice
Ken
The headers are Hooker Competition. I don't have the part #. This is a BBC conversion. The car originally had a 327. I have the offset BBC frame mounts and transmission mount installed. Turbo 400 w/ the correct transmission cross member.
post #4 of 9 (permalink) Old Aug 16th, 17, 12:45 PM
Matt
What type of cylinder heads do you have? If they are aftermarket, do they have stock or raised exhaust ports?
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #5 of 9 (permalink) Old Aug 16th, 17, 02:30 PM
A 600 steering box will buy you a little room. Not cheap though.
https://www.turnone-steering.com/col...formance-model
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #6 of 9 (permalink) Old Aug 16th, 17, 04:17 PM
Ken... All the right questions are being asked. I was in the same boat, X44 car now with a BBC 454, Super T10 4-speed, Iron 781 Oval port heads. All the mounts are correct, my Hooker Competition headers were bought new but dimpled (frustrated mock-up) and I also added a '96 JGC steering box to the mix. All Saginaws that are similar to the IROC '84 box are supposedly 1/8" wider, but I never actually mic'd them up. I used Moroso 3/16" shims and it helped, but in hindsight, I could've used the whole 3-piece set and picked up another 1/8" probably. Pretty sure you have to raise _both_ sides to get the full benefit.
Take a look at a set of Hooker Super Comps... pretty expensive but the problem tube goes up and over so it never gets near the steering box. Just very expensive, and if money's no object, go with Lemons.
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #7 of 9 (permalink) Old Aug 17th, 17, 06:41 AM Thread Starter
Apprentice
Ken
They are stock cast iron heads.
post #8 of 9 (permalink) Old Aug 17th, 17, 06:44 AM Thread Starter
Apprentice
Ken
Any thoughts on the Vega power steering box from CPP?
post #9 of 9 (permalink) Old Aug 17th, 17, 06:58 AM
Billy Morris
Contact Headman Headers. The Hustler series work well.
Even though I have a small block with the big tubes.
I have a Camaro with a 383 & the 600 box, the Hustler
headers have plenty of clearance for the P/S & spark plugs.
Billy
morrisclassic is offline
