Adjusting brake booster questions. - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 17th, 17, 10:07 PM Thread Starter
Bruce
Well I installed a brake booster to convert from manual to power drum brakes. It wasn't a full kit, just the booster with 2 rods and a clevis and a couple of hardware pieces. OH - and NO instructions, thanks Right Stuff. Here is the booster I bought. https://www.summitracing.com/parts/RSD-RPB1001
It worked great at first, but now the brakes are dragging - hard. I am using it with the manual brake master cylinder, it has a 1" piston.
I assume I just need to shorten the rod from the brake pedal to the booster?? Yes, I used the lower hole. I did adjust the rod longer than the manual brake rod.
I read that I'm NOT supposed to use the pedal return spring, is that true? The return spring currently is not hooked up.
Last - the brake pedal DOES hit the stop at the top of the return. I also read it should not??? Where should it stop, and the spring should NOT be used? Why??
Thanks for the help.
Coach62 is offline
post #2 of 5 (permalink) Old Aug 19th, 17, 07:47 AM
Re: Adjusting brake booster questions.
My 67 AIM states .06-.25 free play pedal movement.
Shorten the rod.
my 67' build thread:
allanjs is offline
post #3 of 5 (permalink) Old Aug 19th, 17, 02:54 PM Thread Starter
Bruce
Yep, I'm going to try that here in a few minutes. I might also remove the bump stop since it's not needed.
I read in an old post that another test is to unbolt the master cylinder and see if it frees up.
I think I just have the clevis just adjusted too long.
Thanks for the input.
Also - I'm going to pull the master cylinder anyway to make sure I didn't put the push rod in backwards.
Coach62 is offline
post #4 of 5 (permalink) Old Aug 20th, 17, 02:29 PM
Ty
69&76's Avatar
take a grinder to the rod.
69&76 is offline
post #5 of 5 (permalink) Old Aug 20th, 17, 03:52 PM
Andrew
Andrew69's Avatar
I had to cut the rod length on mine. I don't remember how much but I did shorten it.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
