bad front wheel shake - Team Camaro Tech
 2Likes
  • 1 Post By onefiness
  • 1 Post By Kamcoman
post #1 of 13 (permalink) Old Aug 21st, 17, 04:27 PM Thread Starter
Probationer
Chris
What would be the cause of a bad front wheel shake after hitting a bump? !969 Z28 with stock front suspension.
C. Clark is offline
post #2 of 13 (permalink) Old Aug 21st, 17, 04:39 PM
Banned
Chet
Worn out ball joints. Worn out tie rod ends. Go to a suspension shop and have the entire front suspension looked at. NOW
akxtreme likes this.
onefiness is offline
post #3 of 13 (permalink) Old Aug 22nd, 17, 05:31 AM
Brent
67Rally's Avatar
Re: bad front wheel shake
You could also have bent the wheel, or knocked a wheel weight off.
67Rally is offline
post #4 of 13 (permalink) Old Aug 22nd, 17, 09:49 AM
Keith
Wheel weights and bent wheel cause problems not related to hitting a bump. Do what onefiness says, get the suspension checked for bad tie rod ends, ball joints, worn out idler arm, worn out control arm bushings, etc.
onefiness likes this.
Kamcoman is offline
post #5 of 13 (permalink) Old Aug 22nd, 17, 10:05 AM
George
Gbauer's Avatar
Could be wheel bearings as well if they're bad enough.
But probably a bad ball joint or something with the steering components. Jack it up and move the wheel by hand and see if you notice anything immediate before driving it to a shop. Might be bad enough to be dangerous to drive. If not then still go to a shop unless you can diagnose it yourself.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #6 of 13 (permalink) Old Aug 22nd, 17, 12:21 PM
Brent
67Rally's Avatar
I'm not discounting Chet's advice, just adding more suggestions.
Can you elaborate on what you meant by "Wheel weights and bent wheel cause problems not related to hitting a bump." please?
67Rally is offline
post #7 of 13 (permalink) Old Aug 22nd, 17, 01:40 PM
Keith
Missing wheel weights and/or bent wheels tend to manifest their problems at certain vehicle speeds. You will usually get a steady shaking over a speed range rather than by hitting a bump. You do not need a bump to feel their presence.
Kamcoman is offline
post #8 of 13 (permalink) Old Aug 22nd, 17, 01:41 PM
You didn't state how big the bump was. That will F up more than just a rim.
COPO is offline
post #9 of 13 (permalink) Old Aug 22nd, 17, 01:47 PM
T.C.
Could be a broken belt in your tire.
BMR Suspension is offline
post #10 of 13 (permalink) Old Aug 22nd, 17, 04:38 PM
Banned
Chet
Could be any one of those things. Point is, it needs to be inspected by a pro.
post #11 of 13 (permalink) Old Aug 23rd, 17, 05:32 AM
Michael
When checking all else fails to identify an obvious cause, check caster,camber & toe as they definitely can have an effect on bump-steer if too far out of alignment.
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
Mike_S is offline
post #12 of 13 (permalink) Old Aug 23rd, 17, 07:43 AM
George
X2 on "bump steer", also have the static / dynamic balance, and runout checked on the front tires.
67 RS Ragtop is offline
post #13 of 13 (permalink) Old Aug 23rd, 17, 09:50 AM
Brent
67Rally's Avatar
Sorry, I read the OP's question as though he developed a wheel shake after hitting a big bump (ie pothole), rather than he gets a wheel shake whenever he hits a bump. It would be good to know what the exact symptoms are, and yes, get it checked out.
67Rally is offline
