tubular arms with hotchkis springs - Team Camaro Tech
post #1 of 12 (permalink) Old Aug 24th, 17, 12:45 PM Thread Starter
Louis
I have a 67 camaro with an ls1 swap that i've been driving for about 8 years now, and everyone from day one of the swap asks, when am i going to drop the front so it sits better...
Well, i have some money to spend now and I just bought 2" drop hotchkis springs from some guy on craigslist for $120. I'm looking at buying some tubular upper and lower control arms Helix brand off of ebay for $234.
I want to know if these helix will drop more, i'm okay to drop 3" total with the springs. Reason im thinking of changing my control arms also is they squeak like crazy and they are rubber too. I rebuild the front suspension back in 2005 and only driven the car about 12k miles and im tired of the squeak since the rebuild. i was young back then and not sure if i tightened the control arms without it settling first so not sure if i bind the bushings that i installed. anyways i would like to know what route should i go tubular or say rebuild them again? and if i do go with tubulars will it be worth it and how much of a drop will i see with the 2" hotchkis?
New 67-69 Camaro 68-74 Nova Firebird Front Tubular Upper&Lower Control Arms Set | eBay
thanks again
Louis
RaiderNation67 is offline
post #2 of 12 (permalink) Old Aug 24th, 17, 02:01 PM
T.C.
Re: tubular arms with hotchkis springs
Those Arms cost what a Good Set of Balljoints cost!
The Question is yours - is your Life worth more than a $50 A-Arm?
BMR Suspension is offline
post #3 of 12 (permalink) Old Aug 24th, 17, 02:31 PM
Put some Delrin bushings in your stock arms. You will likely be sorry if you drop more than 2". No need to drop several hundred to a thousand dollars on arms for your application...
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #4 of 12 (permalink) Old Aug 24th, 17, 06:04 PM Thread Starter
Louis
Sent from my iPhone using Tapatalk
post #5 of 12 (permalink) Old Aug 24th, 17, 06:06 PM Thread Starter
Louis
Sounds good I will just rebuild my LCA & UCA again probably going with rubber
Louis
post #6 of 12 (permalink) Old Aug 24th, 17, 06:44 PM
Vega$69's Avatar
Staying with the stock arms and hotchkiss 2" springs is a good way to go. You can change the bushings. May want to think about delrin
Vega$69 is offline
post #7 of 12 (permalink) Old Aug 24th, 17, 08:06 PM Thread Starter
Louis
The derlin cost $300 too much for bushings what do you guys think of the moog
post #8 of 12 (permalink) Old Aug 24th, 17, 08:14 PM Thread Starter
Louis
Another thing is I am just driving the car not doing any auto cross I might do a donut once in a blue moon or get sideways when trying to blow steam but other than that what is the purpose of the Derlin ?
post #9 of 12 (permalink) Old Aug 24th, 17, 10:11 PM
Delrin won't squeak... Moog should be fine though.
dhutton is offline
post #10 of 12 (permalink) Old Aug 24th, 17, 11:19 PM Thread Starter
Louis
Thanks Don.
post #11 of 12 (permalink) Old Aug 27th, 17, 12:46 PM
If you're buying a full set of (new) Helix uppers and lowers (four pieces) for $234 thats a steal. I'd double check and make sure.
I haven't got my invoice handy but I think I paid more than double that... probably closer to $600+. BTW, I installed them with Hotchkis 2" springs, too low so I added Global West .750" coil seats. Also used ProForged BJs all around.
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is online now
post #12 of 12 (permalink) Old Aug 27th, 17, 05:30 PM
David Pozzi
davidpozzi's Avatar
You want Delrin Greasable bushings if at all possible. They reduce friction, don't squeak, or wear like Polyurethane. There is a ride quality improvement when going to a Delrin bushing due to the lower friction. You can run stiffer springs and not have as rough a ride, so body control is better.
davidpozzi is offline
