Hydroboost questions - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 2nd, 17, 11:55 AM Thread Starter
Apprentice
Nick
Hello everyone! I'm having problems with my brakes, hard pedal slow stopping just a nightmare, I've replaced everything, lines calipers, pads, master cylinder, added a vacuum pump as wel, the only thing I did not replace is the booster it's self but it's brand new. Could it be bad out of the package? If not my main question is hydroboost, I put rack and pinion on it with a low flow 850psi power steering pump would this make the hydroboost worthless? Any help would be great I'm smashing my head against the wall!!
Nick
Crack is offline
post #2 of 6 (permalink) Old Sep 2nd, 17, 02:44 PM
Steven
stamatisg1977's Avatar
Ive heard recently on this forum that if the rod from the booster is pushed in too far either from shipping or misuse that it could possibly render the booster useless
Do a quick search
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 6 (permalink) Old Sep 2nd, 17, 02:55 PM
Chris
stinger67's Avatar
Re: Hydroboost questions
Is the booster doing you any good? You say its new? what size? Those mini-boosters are not the same as the 11" stock power boosters. Also some guys are running a pretty good size cam that doesn't create enough vacuum to make a power booster worth while (especially the small one).
stinger67 is offline
post #4 of 6 (permalink) Old Sep 2nd, 17, 03:33 PM Thread Starter
Apprentice
Nick
It's an 8 inch dual, I have a vacuum pump to keep the pressure up, I may be able to get a 9 inch in there but it's super tight.
Crack is offline
post #5 of 6 (permalink) Old Sep 4th, 17, 05:30 PM Thread Starter
Apprentice
Nick
Ordered a new booster I'll update of it fixes the issue
Crack is offline
post #6 of 6 (permalink) Old Sep 9th, 17, 02:40 PM Thread Starter
Apprentice
Nick
Break booster problem and questions
Ok new booster fixed the issue completely, so if you have a hard pedal and it will not come back up all the way it's a bad break booster.
Crack is offline
