Need to redo my brake set up....again. - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 11th, 17, 04:04 PM Thread Starter
Jason
jay'srs/ss's Avatar
Hello all! Haven't been on the forum for a loooong time. My camaro was hibernating, I had a lot going on. Got married, had a kid, switched jobs, it's been crazy. Now that things have settled a bit it's time to get the camaro back on the road. I got her on the road the other day, and my brakes suck!
After going 4 wheel disc I've had issues w/ poor braking/pedal feel. This is my current set up:
Baer Brakes 4 Wheel Disc Kit, Track Front/Sport Rear
Detroit Speed Master/Booster Combo
Baer Brakes Adjustible Prop Valve
I had a shop install this, it was a while ago. I think the main issue is with the plumbing of the lines.
It has what I believe to be is 2 different sized lines. The front has what appears to be the orig line, 3/16? And the rear has a new larger diameter tubing.
Front brake line goes from the master, to the stock metering block on the subframe, out to the brakes.
The rear line goes from the master, to the prop valve, to the metering block, out to the brakes.
My thoughts are to go manual w/ 15/16" or 1" bore master, take out the metering block, replumb everything w/ the same size tubing 3/16.
Thanks in advance for any advice. Hoping to order all the parts/tools I need to get it back on the road and safe and fun to drive!
My Cars:
70 Lemans Sport 350 w/ 48k Original Miles!!! SOLD!!!
SOLD!!!
88 Camaro IROC-Z SOLD!!!
SOLD!!!
jay'srs/ss is offline
post #2 of 6 (permalink) Old Sep 11th, 17, 04:49 PM
Re: Need to redo my brake set up....again.
Size of tubing is irrelevant. You will likely regret going manual. It will likely get worse. Lots of stories about this on the pt forums. I would remove the metering block and try it from there.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 6 (permalink) Old Sep 12th, 17, 06:18 AM
Jeff
yellow69RS's Avatar
The factory lines are two different sizes on all drum or disc drum set ups. I doubt that is your trouble. Do your rear calipers have emergency brakes in them? if so IMHO that is the problem.
Jeff
yellow69RS is offline
post #4 of 6 (permalink) Old Sep 12th, 17, 06:22 AM
Jeff
Pretty sure Baer brakes have internal drum e-brake and not that Mickey Mouse Cadillac/metric caliper e-brake so that should not be an issue.
OP should rebleed the entire system including a bench bleed of master before yanking parts imho.
post #5 of 6 (permalink) Old Sep 12th, 17, 11:49 AM
David Pozzi
davidpozzi's Avatar
Don't go to manual brakes. The caliper piston bores in the Baer track kit are smaller than stock and require a smaller master cyl bore. 15/16" is a good size for power brakes. To do a manual system, you'd have to go to a 3/4" to 13/16" bore master cyl.
The master cyl has to fit the booster properly, there are two versions of GM master cyls, the difference is the depth of the rear pushrod hole, a shallow and deep version to match the two lengths of pushrods from booster to master cyl. The pushrods pulls out of the booster and most replacement boosters come with two pushrods so you can select the one that fits your master cyl.
If booster to MC pushrod length is too long, it may prevent proper bleeding of the system due to lack of replenishment to the MD bores. The MC pistons have to return to the rear fully in order to open the replenishment ports and allow fresh fluid to fill the bores. If your pedal is firm and high, it's probably OK. if your pedal is spongy and low, either the above pushrod is not allowing good replenishment or you still have air in the system.
We have found it's very helpful to bleed a new system, drive the car a while, then re-bleed the brakes manually. There are often a few bubbles stuck in the system and driving the car helps shock them loose and they combine to larger bubbles that can be then bled from the system.
davidpozzi is offline
post #6 of 6 (permalink) Old Sep 12th, 17, 01:16 PM Thread Starter
Jason
jay'srs/ss's Avatar
My pedal is low and spongey. And it doesn't come back up very good at all. I tried to bleed the brakes last night and it was going good until I got to the driver side front caliper. Could not get it bled, kept getting bubbles. I started poking around for leaks, and sure enough the dist block on the subframe is leaking. So I'm going to take that out, replace w/ a tee fitting, bleed it all again and see how it feels.
My Cars:
SOLD!!!
SOLD!!!
