How to remove 68 camaro upper A arm on drivers side - Team Camaro Tech
 1Likes
post #1 of 16 (permalink) Old Sep 13th, 17, 06:37 PM Thread Starter
I'm replacing the bushings in the upper control arms. I've already done the passenger side by removing the headers. I'm now attempting to do the driver's side. I've unbolt ed the headers, but I can't push them down enough because it's hitting the steering box. I don't think I can get them out of the way enough without jacking up the motor. Can I try to push the bolts out of the frame with a c clamp? Then I can lift the arm straight up. I'm trying to do this the easiest way.
tireburner396 is offline
post #2 of 16 (permalink) Old Sep 13th, 17, 06:43 PM
Re: How to remove 68 camaro upper A arm on drivers side
Yes, they are just pressed in.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 16 (permalink) Old Sep 13th, 17, 06:46 PM Thread Starter
Can I reuse the bolts? I'm assuming they have the knurled shoulder so they won't spin.
post #4 of 16 (permalink) Old Sep 13th, 17, 07:11 PM
Yep. At least I have.
post #5 of 16 (permalink) Old Sep 14th, 17, 12:59 AM Thread Starter
So I should be able to get a c clamp in thete, with the control arm still in there?
post #6 of 16 (permalink) Old Sep 14th, 17, 03:52 AM
No idea, just saying it is ok to press them out. You are likely just going to have to try.
post #7 of 16 (permalink) Old Sep 14th, 17, 07:57 AM
Probationer
Ed
I have done it on many cars !!
sptrucksbyed is offline
post #8 of 16 (permalink) Old Sep 14th, 17, 09:42 AM
Michael
I've removed those bolts easily by placing a nut over the threaded end (to prevent thread damage) and tapped them out with a hammer.
The base of the bolt head has raised groves which is all that is securing them into the frame.
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
Mike_S is offline
post #9 of 16 (permalink) Old Sep 14th, 17, 10:48 AM Thread Starter
Unfortunately there is no room to even swing a hammer in there. I'm hoping I can fit a c clamp and get them out. I really don't want to jack up the motor and all that crap
post #10 of 16 (permalink) Old Sep 14th, 17, 05:04 PM Thread Starter
I ended up cutting them, and got the control arm out. Now that the arm is out of the way, I can get a clamp on it and press them out. Took a ride and picked up new bolts before I cut them!
post #11 of 16 (permalink) Old Sep 14th, 17, 07:59 PM
Tom Anderson
I have always been able to get the drivers side header out by jacking the car very high and support it with a jack stand for safety and just twist and move it around till you find that magic spot and it will twist and come out . It takes time and lots of patience's but it will go in and out just not easy . Just my 2 cents
socal_tom is offline
post #12 of 16 (permalink) Old Sep 15th, 17, 12:58 AM Thread Starter
I'm sure I could have, the problem is I'm changing the control arms while the control arms while the car is on the lift. I am already using the jack tray to support the car while I have this side apart, and it's too far forward to use to jack the motor up.
post #13 of 16 (permalink) Old Sep 15th, 17, 04:25 AM
Michael
I have successfully added&removed headers on a '67 BB (and you know how tight that space can be) by removing only the drivers side motor mount bolt and placing a piece of plywood under the pan and jack up the motor where it pivots on the passenger side mount enough to clear the steering box to remove the headers.
socal_tom likes this.
Mike_S is offline
post #14 of 16 (permalink) Old Sep 15th, 17, 10:44 AM Thread Starter
Thanks for that info. If I have to change the headers I'll keep that in mind.
post #15 of 16 (permalink) Old Sep 16th, 17, 03:57 AM Thread Starter
I had to use a slide hamer to pound the bolt out of the frame. The arm is all back in!!
