Rear Brake Lines - Team Camaro Tech
post #1 of 1 (permalink) Old Sep 30th, 17, 05:03 PM Thread Starter
Lee
Rear Brake Lines
Just curious what the difference is between the mono and multi-leaf read brake line are? My car had mono leafs but then I swapped them out for the Hotchkis multi-leafs. When I ran the new U-bolts over the axel I did need to "stretch" them just a little to clear the u-bolts. I need to order new ones to replace a line that has a stripped nut to the rear brake cylinder. I am tempted just to order the mono lines again as thats whats on there now but wanted to ask if I should be buying the multi-leafs instead now.
1968 Camaro with a 383 finally done and on the road!
LeeMan is offline
