DSE rear spring pocket kit - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 6th, 17, 04:03 AM Thread Starter
I am wondering if anyone has seen this setup installed. Does it do anything more than allow the front pocket vertical adjustment?
3d cad is offline
post #2 of 4 (permalink) Old Oct 6th, 17, 05:34 AM
Vega$69's Avatar
Re: DSE rear spring pocket kit
Other te allowing you do bolt front spring eye 1" higher I don't see it is worth $400 plus the labor to install.
It is stronger but I don't think the stock pocket is too weak and never seen one fail.
Vega$69 is offline
post #3 of 4 (permalink) Old Oct 6th, 17, 05:40 AM
Jeff
yellow69RS's Avatar
Raising the front spring mounting point was an idea I saw in a book by Herb Adams many years ago. It changes the suspension geometry slightly much like the Guldstran mod does to the front. Not sure that I could find said reference if I tried to give a better understanding of what effect it has. My concern would be interference to the top of the bracket if you were to redrill a stock one.
Jeff
yellow69RS is offline
post #4 of 4 (permalink) Old Oct 6th, 17, 06:19 AM
Jeff
Herb Adams (a senior GM engineer who worked on the second generation Firebird suspension credited with the invention of the wonder bar) talked about it in his book "Chassis Engineering".
Big Dave
Larger Dave is offline
