Wilwood front disk brake line routing??? - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 7th, 17, 01:39 PM Thread Starter
Apprentice
Michael Lockwoo
Does anyone with a similar setup have a picture of their front brake line routing/plumbing? I have Wilwood disks and their master cylinder and prop valve as pictured here. I ordered a complete set of pre-bent lines from Right Stuff. I just can't see how to connect the hard lines to the calipers AND still use the original brake line brakes at the frame. Am I supposed to use the original flex-line to frame brackets up front? The original brackets won't accommodate these lines with Wilwood's braided lines. Any clue as to what I am missing?
In the last picture, you can see how the passenger side hardline hangs over the frame. Is the line supposed to sit like this?
Thanks for any input!
Mike L is offline
post #2 of 4 (permalink) Old Oct 7th, 17, 02:01 PM Thread Starter
Apprentice
Michael Lockwoo
Re: Wilwood front disk brake line routing???
I think I may have found the problem. I am trying to use frame brackets for an original disk brake car. I think these aftermarket hardlines want to connect to the drum brake line brackets. Does this sound correct?
Mike L is offline
post #3 of 4 (permalink) Old Oct 7th, 17, 02:18 PM
Simon
First off, lets work from the caliper to the brake line. Probably a 10mm banjo fitting(check your calipers or with Wilwood or their website), from there you'll need a hose, then an adapter to fit the 3/16" original hard line.
Here's a few links to get an idea.
640471.......Adapter Fittings - Brake and Clutch Hose - Russell Performance Products
656242..........Universal Brake Hose - Brake and Clutch Hose - Russell Performance Products
641411........Adapter Fittings - Brake and Clutch Hose - Russell Performance Products
This is what I used to swap out my front Z51 vette brakes from Kore brakes. You'll have to measure your hoses once you turn the wheel lock to lock. I used the factory hose bracket and the retainer and it works out fine with these fittings.
Hope this helps.
slazisme is offline
post #4 of 4 (permalink) Old Oct 7th, 17, 02:28 PM
Simon
Here's a not so great pic of the passenger side, you can see the banjo bolt with the crush washers
One thing I would recommend is to stay with the same manufacturer when combining fittings.
slazisme is offline
