Slow Leak Bottom Of Diff Pumpkin - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 10th, 17, 05:52 AM Thread Starter
Joe
I drilled and tapped for a drain plug and it has a slow leak. If I wipe and glean carefully with diff full of gear oil, is there anything I can paint or slather over the area to stop this slow leak. Something non hardening. I don't want to cement it just to cover with sealant.
1965tripleblack is offline
post #2 of 4 (permalink) Old Oct 10th, 17, 06:05 AM
Steven
stamatisg1977's Avatar
Just use pipe thread tape
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 4 (permalink) Old Oct 10th, 17, 07:35 AM
mccorry's Avatar
Re: Slow Leak Bottom Of Diff Pumpkin
Or clean everything up with brake cleaner, install a light coat of Grey RTV (Oil proof) on the threads before threading the plug into the housing. Give it a little time (few hours) to set up and then add the oil.
Steve -
'69 Camaro RS/SS-350, TH350, factory air, factory AM/FM, factory tilt wheel, console w/ gauges - Daytona Yellow
- 1969 Van Nuys Camaro Database
mccorry is offline
post #4 of 4 (permalink) Old Oct 10th, 17, 08:01 PM
Jimmie-Retired
Like Steven said, pipe dope or teflon tape. Your diff has a vent so it shouldn't build any pressure.
Jim's '69
68 SS 396 4 speed A/C Bought New Sold 1976
68 350/350 A/C Bought 1978 $700 Wrecked
69 350 4 Speed Bought 1988
Fried Okra is offline
