Removing pinion snubber - Ridetech 4link - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 5th, 17, 04:57 PM Thread Starter
Kurtis
I am installing the Ridetech 4Link and am having trouble removing the pinion snubber bracket. Does anyone know how you remove it? Are there spot welds and if so where are they located?
Kurtismcm is offline
post #2 of 6 (permalink) Old Nov 5th, 17, 05:25 PM
Re: Removing pinion snubber - Ridetech 4link
Yes there are spot welds but they are not accurately placed. Just get a cutoff blade on an angle grinder and start cutting. They will reveal themselves eventually as you cut away at it.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 6 (permalink) Old Nov 5th, 17, 05:36 PM Thread Starter
Kurtis
Where do I cut? The bracket lays flat
post #4 of 6 (permalink) Old Nov 5th, 17, 05:45 PM
Sorry I canít remember the details. I just hacked away at it a piece at a time. I think I knocked the last bits of it off with an air chisel.
Nasty job laying on your back if that is what you are doing. Even on a lift it is not fun.
post #5 of 6 (permalink) Old Nov 5th, 17, 05:55 PM
Jonathon
Smitty68's Avatar
I didnít remove mine. Just remove the snubber and cut off the excess thatís in the way of the cradle.
I can send a pic if you need it already installed??
68 Resto-Mod in progress..355sbc .350 Trans Rushforth wheels
My Build:
Smitty68 is offline
post #6 of 6 (permalink) Old Nov 23rd, 17, 07:58 PM
David Pozzi
davidpozzi's Avatar
You can see dimples where the spot welds are. Drill them out. A spot weld drill works best. This type worked best for me: https://www.walmart.com/ip/Neiko-HSC...&wl13=&veh=sem
Name:	IMG_0383 pinion snubber.jpg
davidpozzi is offline
