Drum MC to Disc MC conversion - Team Camaro Tech
post #1 of 7 (permalink) Old Nov 17th, 17, 02:39 AM Thread Starter
The Disc MC is larger and heavier than the drum MC. Is that not a big deal, or do I need to provide additional support or some kind of bracket for it to mount to the firewall?
Thanks,
BH
BigHog is offline
post #2 of 7 (permalink) Old Nov 17th, 17, 05:59 AM
Vega$69's Avatar
Re: Drum MC to Disc MC conversion
Not sure what your'e comparing. They are both the same size with only bore size being different.
To answer your question NO additional support is needed.
Vega$69 is offline
post #3 of 7 (permalink) Old Nov 17th, 17, 06:12 AM Thread Starter
The Disc MC is a bit larger overall and heavier. I already threw out the drum MC, so i cannot do a comparison photo or weight comparison at this point. But it is heavier. I was skimming through one of my Camaro restoration catalogues, and came across a MC firewall reinforcement plate. I haven't read anything on it, just figured if they made the part, there must be a reason for it. So I thought I'd ask in here, figuring some of you guys must have knowledge of it.
Now me being the impatient person that I am, I just bought one from Inline Tube. Here is a similar one on eBay. https://www.ebay.com/itm/64-74-GM-A-...lZdkAc&vxp=mtr
BigHog is offline
post #4 of 7 (permalink) Old Nov 17th, 17, 06:18 AM
Vega$69's Avatar
Won't hurt but I've never used one or seen one used.
As you can see in the Ebay item pic the MC bolts to the studs and sandwiches the firewall. I don't see what the reinforcement plate is reinforcing.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #5 of 7 (permalink) Old Nov 17th, 17, 06:23 AM Thread Starter
By the looks of it, I figured it was reinforcing the metal around the studs. To keep the studs from pulling through the firewall? In the end, I went with the thought that it can't hurt as well.
BigHog is offline
post #6 of 7 (permalink) Old Nov 17th, 17, 06:46 AM
George
Gbauer's Avatar
Dont need it.
They weren't put in by the factory and they've gone 50 years without problems so it doesn't need to be done now.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #7 of 7 (permalink) Old Nov 17th, 17, 06:53 AM Thread Starter
Rgr that!
BigHog is offline
