do I need subframe connectors with 350hp/400tq? - Team Camaro Tech
 11Likes
post #1 of 36 (permalink) Old Nov 17th, 17, 06:37 AM Thread Starter
67 Camaro coupe
350 RamJet (350hp/400tq)
stock frame and front clip, front tubular control arms, Hotchkis rear swaybar
handles tight, feels fine to me
should I have subframe connectors?
David in NC is offline
post #2 of 36 (permalink) Old Nov 17th, 17, 07:15 AM
Andrew
Andrew69's Avatar
Re: do I need subframe connectors with 350hp/400tq?
Absolutely. You will be surprised how much more rigid your car will be with them. I noticed it most when going over railroad tracks at an angle when the car would twist.
Put this in your trunk to reduce flex in the rear. https://www.summitracing.com/parts/h...SABEgKuovD_BwE
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 36 (permalink) Old Nov 17th, 17, 07:22 AM
kevin
I am over 500' of torque and don't have them, but I do not run any type of slick and very seldom launch from a stop
flat tire is offline
post #4 of 36 (permalink) Old Nov 17th, 17, 08:23 AM
Steve69SS396's Avatar
No, you don't need them. Years ago I ran mid 10's at 128 with slicks and no connectors in my '69.
Steve69SS396 is offline
post #5 of 36 (permalink) Old Nov 17th, 17, 08:45 AM
Fred
77thor's Avatar
IMO, every first gen would benefit from having SFC's.
sleepsinshed, DT and ChrisG like this.
77thor is offline
post #6 of 36 (permalink) Old Nov 17th, 17, 08:52 AM
mike
It couldn't hurt.
DT likes this.
bigblockragtop is offline
post #7 of 36 (permalink) Old Nov 17th, 17, 09:06 AM
Patrick
My weld in subframe connectors recommended to use solid bushings between the subframe and the body.
Do bolt on type subframe connectors also require solid bushings?
Patrick
tp_smith is offline
post #8 of 36 (permalink) Old Nov 17th, 17, 09:14 AM
Subframe connectors are not just for drag racing. They stiffen the unibody and improve handling as a result.
DT likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #9 of 36 (permalink) Old Nov 17th, 17, 02:18 PM
mike
I have a big block convertible, I NEED them.
sleepsinshed likes this.
post #10 of 36 (permalink) Old Nov 17th, 17, 03:21 PM
DT
Donny
DT's Avatar
Which SFC do you have ?? My Hotchkis came with the new bushings. Bolt-on or weld-on for the front, its users choice. The rears are welded up only.
DT is offline
post #11 of 36 (permalink) Old Nov 17th, 17, 05:19 PM
Never hurts to add them
Suspension is supposed to do the work and if the body flexes, the suspension looses its control over the what the tires are supposed to be doing.
Moonpie likes this.
68 Camaro~LSx ~all motor
post #12 of 36 (permalink) Old Nov 17th, 17, 06:51 PM
I highly recommend SFC's even if you don't think you need them. You will notice a difference for the better.
The idea behind solid bushings with weld-in SFCs is because the connectors need to be removed to R&R subframe bushings, which would require cutting welds to do so. I'd also recommend solid subframe bushings on any first gen, SFCs or not.
BPOS is offline
post #13 of 36 (permalink) Old Nov 17th, 17, 07:50 PM
I completely agree with you. Does he need them, no. Will they stiffen the car and improve handling. Yes.
arocars likes this.
post #14 of 36 (permalink) Old Nov 17th, 17, 07:56 PM
Tom Anderson
I always put a set on my cars I build , they can be a pain in the *** to fit but never hurts to add strength to a car like others have said
57vette likes this.
socal_tom is offline
post #15 of 36 (permalink) Old Nov 18th, 17, 05:32 AM
Do you use ready-makes or make your own? I seem to recall a old thread with instructions on making your own. Can't find it this morning but the first cup of caffeine hasn't kicked in yet.
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
