Brake pedal drops to the floor - Team Camaro Tech
 2Likes
post #1 of 26 (permalink) Old Nov 18th, 17, 12:36 PM Thread Starter
Tony
OK, all new brake system, front and rear discs. Just got a new master cylinder and the brake pedal just drops to the floor and no stopping. I can pump them up but the pedal just sinks...
Bad Master cylinder?
Tony
Follow my current Camaro project builds...
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
bondora68 is offline
post #2 of 26 (permalink) Old Nov 18th, 17, 04:41 PM
Steven
stamatisg1977's Avatar
Did you do the basics?
Bench bleed mc
Bled system starting at furthest wheel from mc to the closest?
Mc rod too short/long?
69-Pace likes this.
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is online now
post #3 of 26 (permalink) Old Nov 19th, 17, 06:09 AM
69-Pace's Avatar
Re: Brake pedal drops to the floor
X2 Yes we need to really know the prep cycle of the master you followed, and all the changes you made to the existing rod and peddle combination.
Could be air, could be a bad master, missing or too short master cylinder push rod. Fill us in.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 26 (permalink) Old Nov 19th, 17, 07:51 AM
Originally Posted by bondora68 View Post
Just got a new master cylinder, I can pump them up but the pedal just sinks...
When the suggestions given are done, this symptom is saying bad master cylinder.
Once pedal is depressed, once or several times, pedal should be rock solid.
Unless a leak has occurred elsewhere.
post #5 of 26 (permalink) Old Nov 19th, 17, 08:03 AM
Steven
There was a time when i redid my whole brake system with new lines original mc and booster. Driving down the road my pedal would go to the floor and you could hear the brakes grinding. Turned out that the booster went bad
bondora68 likes this.
Tremec TKO 600
post #6 of 26 (permalink) Old Nov 19th, 17, 06:04 PM Thread Starter
Tony
Thanks to all of you for the advice, I may have it sorted out.. My new master cylinder came with a little insert that is shaped like a bullet and goes into the end where the rod inserts. I removed that insert and then rebled the MC. I then rebled the system and got a pedal. Not a really tall pedal mind you but brakes seem to be working. Tomorrow I will take a test drive around the block to check it out.
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #7 of 26 (permalink) Old Nov 20th, 17, 11:09 AM
DjD
DjD's Avatar
It's been too long but I do remember the bullet is used with a booster and not used if manual brakes. There is also 2 positions for the clevis rod to connect to the pedal. also there should be threaded adjustment between the clevis & rod and the rod may need to be cut and hopefully not already cut too short. when I did my 4 wheel manual disc's the issue I ran into was the pedal was too high off the floor.
...Dennis
DjD is offline
post #8 of 26 (permalink) Old Nov 20th, 17, 06:25 PM
David Pozzi
davidpozzi's Avatar
Two pushrod lengths
Two MC hole depths:
The difference is 1.350"
Generally the deep hole master was used on manual brake systems, so the pushrod would not fall out if the pedal was pulled back quickly by the return spring. The short depth masters are for power brakes, but GM did use a cup adapter to use them on manual brake equipped second gens.
davidpozzi is offline
post #9 of 26 (permalink) Old Nov 21st, 17, 05:08 PM Thread Starter
Tony
After a really short test drive, the pedal still sinks to the floor....I can pump it up but it does not hold. I unscrewed the rod out as far as it would go...
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #10 of 26 (permalink) Old Nov 21st, 17, 05:23 PM Thread Starter
Tony
According to the above information, my new master cylinder is for a manual brake set up! Maybe that's the problem..?
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #11 of 26 (permalink) Old Nov 21st, 17, 06:47 PM Thread Starter
Tony
Could it be the booster?
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #12 of 26 (permalink) Old Nov 22nd, 17, 10:22 AM
Chris
You can still use a manual brake MC with a booster, but as discussed, you need to have the correct rod from MC to booster for sure. Measure your old MC and rod and make sure the new MC rod or rod with extension is the same exact length as your original setup relative to the booster. If the rod is too long, it won't let the the MC piston retract fully.
You should be able to plug both ports on the new MC and get a firm pedal, then the MC is good. These things are tested before sales, even the rebuilt ones, so it should be ok, but I've heard sometimes they aren't.
These pedal collapsing to the floor problems are almost always an issue with air in the system somewhere. Unless I missed it, not sure you mentioned if you bled the MC properly prior to installation.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #13 of 26 (permalink) Old Nov 22nd, 17, 01:05 PM Thread Starter
Tony
I tried my best to bench bleed the MC. What is the best method to do this?
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #14 of 26 (permalink) Old Nov 22nd, 17, 01:33 PM
Steven
get one of these
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
install the fittings run the tubes into the mc bowls filled with brake fluid
push the plunger in and out until you see no air bubbles exiting the tubes
Tremec TKO 600
post #15 of 26 (permalink) Old Nov 22nd, 17, 02:16 PM
You can bench bleed without the tubes. I do it this way with no issues. https://www.cardone.com/tech-help/br...ding-procedure
Call for restoration and custom paint scheduling:
Sauron67MM is online now
