Bolt on 4 link - Team Camaro Tech
 1Likes
post #1 of 17 (permalink) Old Nov 20th, 17, 02:54 PM Thread Starter
RDW
Bob
Bolt on 4 link
So I have decided to add a bolt on 4 link suspension to my 67 to improve the ride. I have looked at the ridetech and the chassis works. Iím just wondering if anyone has any experience with either of these or any other 4 link set ups. Iím not going to race the car just looking for a better ride
67 Camaro coupe 327 automatic
78 RS Camaro 350 automatic (sold)
RDW is offline
post #2 of 17 (permalink) Old Nov 20th, 17, 03:09 PM
Steven
stamatisg1977's Avatar
Re: Bolt on 4 link
i have the ridetech. fits great just take your time installing it and keep measuring
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 17 (permalink) Old Nov 20th, 17, 03:28 PM
Re: Bolt on 4 link
They are nearly identical geometry but Ridetech shocks are much better. Iíve owned both setups.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #4 of 17 (permalink) Old Nov 21st, 17, 07:14 AM
T.C.
Re: Bolt on 4 link
I sell a lot of our Torque Arm Kits!
BMR Suspension is offline
post #5 of 17 (permalink) Old Nov 21st, 17, 07:35 AM
Vega$69's Avatar
Re: Bolt on 4 link
I prefer the torque Arm over 4 link for a street car
Vega$69 is offline
post #6 of 17 (permalink) Old Nov 21st, 17, 07:53 AM
Jeff
Re: Bolt on 4 link
I don't know that a 4 link is going to improve the "ride" quality any, I think its more for tracking. I have Hotchkis lowering springs with Vari-shock SS shocks and the ride quality is quite good. The shocks themselves make a huge difference in ride quality. I tried several sets including the Hotchkis recommended Bilsteins and they were all too harsh for my liking. I guess if you were going to track the car you would want it stiff but its not much fun for everyday cruising.
And this too shall pass.
69 X11 SS, Glacier Blue, LS3 480, T56 Mag, Lots of stuff done to it, all by yours truly
Build thread:
workng247 is offline
post #7 of 17 (permalink) Old Nov 21st, 17, 09:22 AM
Re: Bolt on 4 link
One advantage of coil over shocks is that the springs are cheap (and used ones that are even cheaper are plentiful around here in the deep south thanks to roundy-round racers). You can collect several different spring rates and swap them as easily as you can change a shock (couple of bolts). As such you can have a set of springs for cruising and another set for the drags, and a third set for track day if you road race or autocross.
Big Dave
Larger Dave is offline
post #8 of 17 (permalink) Old Nov 21st, 17, 10:04 AM
Re: Bolt on 4 link
After two canted four bar cars my next car will have a Speedtech torque arm. Just never been impressed by the ride of the four bar cars. Not sure if it is geometry related or what...
dhutton is offline
post #9 of 17 (permalink) Old Nov 21st, 17, 02:09 PM Thread Starter
RDW
Bob
Re: Bolt on 4 link
Guys thanks for the input youíve given me a few things to look at. I appreciate it.
RDW is offline
post #10 of 17 (permalink) Old Nov 25th, 17, 04:34 PM
David Pozzi
davidpozzi's Avatar
Re: Bolt on 4 link
Ride Tech just came out with a new "R Joint" that is Delrin lined, rebuildable, and absorbs shocks pretty well. I think it will be incorporated into all their rear link suspensions. They are doing a lot of improvements based on all the Autocross they have been doing. A torque arm or link rear suspension will ride better than leaf springs. The Ride Tech Street grip kit is a great choice for street driven Camaros. The composite leaf springs ride better due to lower unsprung weight, and don't transmit shocks as much as steel springs.
davidpozzi is offline
post #11 of 17 (permalink) Old Dec 18th, 17, 10:52 AM
foreverlookin's Avatar
Re: Bolt on 4 link
It would be great if these would fit....
foreverlookin is offline
post #12 of 17 (permalink) Old Dec 18th, 17, 11:50 AM
Re: Bolt on 4 link
They do, sort of:
https://www.artmorrison.com/multi-link-IRS.php
Moonpie likes this.
dhutton is offline
post #13 of 17 (permalink) Old Dec 18th, 17, 11:56 AM
Vega$69's Avatar
Re: Bolt on 4 link
Here's one that fits
1967-1969, 1970-1973 Camaro IRS Independent Rear Suspension Kit & Parts - HEIDTS
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #14 of 17 (permalink) Old Dec 18th, 17, 01:41 PM
Re: Bolt on 4 link
Originally Posted by Vega$69 View Post
Not a fan of those inboard brakes. That setup is more street rod than muscle car....
dhutton is offline
post #15 of 17 (permalink) Old Dec 18th, 17, 01:53 PM
Darin
ilikeike's Avatar
Re: Bolt on 4 link
It does remind you of looking at the rear of a street rod, but it is unsprung weight. race car!
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
