Prop Valve frustration - help needed - Team Camaro Tech
 1Likes
post #1 of 18 (permalink) Old Dec 4th, 17, 06:36 AM Thread Starter
Granted, I have zero experience doing all the work I am doing to my Camaro, but I enjoy it (for the most part), and it's the only way I can afford to fix her. I have been trying to upgrade to Disc brakes. I bought a brand new Disc/Disc MC and a Disc/Disc Prop valve. Trying to fit everything up and figure out how to connect everything, is like having a puzzle with missing pieces and trying to figure out what pieces you need to finish.
Bench bleeding the MC, and installing it, was no problem. The prop valve on the other hand has been giving me fits. I finally got the right adapters I need (thanks to Inline Tubing), to connect the brake lines to the prop valve, and from the prop valve to the MC. However, the prop valve is not connected to a bracket. I could not figure out what bracket to use and how to configure it, to work. So right now it's only being held in place by the various brake lines. I need help figuring out how to connect the prop valve with a bracket, or is it fine to not use a bracket?
Thanks in advance for any and all help.
BH
BigHog is offline
post #2 of 18 (permalink) Old Dec 4th, 17, 04:05 PM
Garth
Re: Prop Valve frustration - help needed
Either way is fine. If Inline Tube doesn't have a bracket you'll need to fabricate one. Use the studs for the MC to fasten it.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
1967 R/T
1977 Power Wagon
69L48Z27 is offline
post #3 of 18 (permalink) Old Dec 4th, 17, 06:42 PM
Rick
Pirate Jack has what you need.
Proportioning Valves - Brackets - Pirate Jack
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is online now
post #4 of 18 (permalink) Old Dec 5th, 17, 02:39 AM Thread Starter
Thanks, guys.
BigHog is offline
post #5 of 18 (permalink) Old Dec 5th, 17, 04:46 AM
Travis
Thanks Rick - yet another parts source I did not know about. Prices look pretty good too for a full 4wheel disc conversion.
travisch is offline
post #6 of 18 (permalink) Old Dec 5th, 17, 12:10 PM
Michael
Disc/disc should only need a distribution valve, nothing more.
If you still have your cast iron distribution valve (and bracket), I suggest cleaning it and putting it back into service.
mahunt is offline
post #7 of 18 (permalink) Old Dec 6th, 17, 02:31 AM Thread Starter
Even if it was from a Drum/Drum setup?
BigHog is offline
post #8 of 18 (permalink) Old Dec 7th, 17, 09:17 PM
Michael
Yup.
mahunt is offline
post #9 of 18 (permalink) Old Dec 8th, 17, 07:25 AM
John, Check with your systems manufacturer to see if a
separate prop. valve is needed. The pressure MUST be
proportioned between the front and rear in some manner
for safe operation. It's not something you want to do
incorrectly. You can read all kinds of pros and cons on
using a prop. valve but the manufacturer knows how
their system was designed. An improperly balanced
system can have disastrous results.
my 67' build thread:
allanjs is online now
post #10 of 18 (permalink) Old Dec 8th, 17, 07:53 AM Thread Starter
I didnt order a system, just parts. COnverting from drum/drum to disc/disc.
BigHog is offline
post #11 of 18 (permalink) Old Dec 8th, 17, 04:07 PM
David Pozzi
davidpozzi's Avatar
You need a proportioning valve for Disc/Disc. What you have looks like a "Combination" valve, which has a proportioning valve, a metering valve, and a brake warning light switch all in one. It gets the job done, but lacks adjustablilty so you need to use factory front and rear brakes that go with that valve setting.
On high performance systems that we autocross and use aftermarket disc/disc combinations, we use just an adjustable proportioning valve in the rear line, and no brake warning light or metering valve. If I wanted a brake warning light, I'd use a drum/drum warning light switch plumbed to the master cyl, and install the prop valve after the switch in the rear line. I've put one before the switch and it worked, but there's a chance it would trigger the warning light that way.
allanjs likes this.
davidpozzi is offline
post #12 of 18 (permalink) Old Dec 9th, 17, 06:10 AM
John, Go to thestopshop.com. They have good video's
explaining the valves and lines used.
post #13 of 18 (permalink) Old Dec 11th, 17, 03:06 AM Thread Starter
Thanks again, everyone. I really appreciate all the information.
BigHog is offline
post #14 of 18 (permalink) Old Dec 11th, 17, 03:23 AM
Brett
So on a Disc/Disc, do you still need the valve that's along the frame rail under the drivers seat?
Brett.....
1969 SS 396 X66 - RS Conversion - TKO600 - 3.73 Posi - Paint Code 71-LeMans Blue
Brettallen59 is offline
post #15 of 18 (permalink) Old Dec 11th, 17, 04:53 AM
Brett.....
That factory valve does not apply to aftermarket disc/disc or the JL8 option. Camaro Chassis - Suspension, Axle, Brakes, & Wheels
Call for restoration and custom paint scheduling:
Sauron67MM is offline
