69 Camaro Rear Brake Conversion with Mini Tub Kit - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 7th, 17, 04:56 PM Thread Starter
Vic
My camaro has rear drum brakes; I would like to convert to disc brakes.
Details: My current rear set up has a dse mini tub kit installed, complete with offset shackles, rear crossmember support for shocks to be repositioned inside of the leaf spring. The leaf springs have a 2" drop. A DSE narrowed gas tank is also installed.
I have a 12 bolt rear with posi. I have not removed the back casing to see whether it has a C clip eliminator.
Question: I am looking at different options from wilwood to american brand conversion kits. I do need to have the parking brake, and want to know the following.
1. do I need to have a disc brake with a drum combo to accommodate the parking brake? Brakes seen here Wilwood High Performance Disc Brakes - Rear Brake Kit Product Number: 140-11398-DR
1a. Does installing this add more of a positive wheel offset, adding more back spacing by pushing the brake assembly further out towards the street?
1b. Does installing this kit give me everything I need to convert from drum to disc, appears the calliper attaches to the drum assembly (Refer to image below).
2. I assume that since I have the DSC mini tub kit installed, I do not have to worry about staggered shocks?
3. This is an example of the american brand rear brakes. Will these accommodate a parking brake (i assume no?)
https://www.ebay.com/itm/GM-10-12-Bo...BSw3Iw&vxp=mtr
4. Lastly, I have not fully decided whether I want narrow my rear end (to accommodate larger rear tires), and if I do, does that change anything with the install of which conversion kit i use.
Vic
1969 Camaro SS
Camaro1969 is offline
post #2 of 5 (permalink) Old Dec 7th, 17, 06:19 PM
Steven
stamatisg1977's Avatar
I have the right stuff detailing and it sticks wheel out 1/4.
Most likely u have c-clips id you dont have the eliminator bearings on the end
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 5 (permalink) Old Dec 7th, 17, 07:12 PM
scblucam's Avatar
Re: 69 Camaro Rear Brake Conversion with Mini Tub Kit
Mine are SSBC and I worked with Lokar to find a solution. As I recall they gave me a kit form a old T-Bird. Works great.
68 302 M20 - 85 IROC Z
scblucam is online now
post #4 of 5 (permalink) Old Dec 7th, 17, 07:22 PM Thread Starter
Vic
Do you have a part number for the kit?
Vic
1969 Camaro SS
post #5 of 5 (permalink) Old Dec 8th, 17, 04:04 PM
Steven
https://www.getdiscbrakes.com/afxrd05
Tremec TKO 600
