Multi Spring upgrade - Team Camaro Tech
 3Likes
  • 2 Post By Vega
  • 1 Post By mferris72
post #1 of 9 (permalink) Old Dec 10th, 17, 09:33 AM Thread Starter
I'm in the process of installing a 12 bolt 3.73 posi, multi spring setup in a 68 Camaro. I have upgraded the front using CPP 1.5 lowering springs. (No drop spindle) and currently have Mono spring rear, ride height is perfect 26.5", floor to top of wheel arch. I suspect the mono's are sagging some with age. I see everything from 3,4,5 leaf options and spring rates from 112-180 lbs. I assume the higher the rate the harder the ride. I'm also installing a 200-4R OD trans, so as you can see I want a pro tour type ride. I'm running a 327 with about 300+HP so not a real powerhouse. My question is::
What # springs and spring rate will give me a comfortable ride?
I am reading that a 2"drop isn't actually 2" lower then stock. Most say it's actually only and inch.
Currently I'm looking at either Detroilt Speed or BMR Suspension springs. I here a lot about Hotckins, but there to high for my wallet.
any comments would be appreciated!
mferris72 is offline
post #2 of 9 (permalink) Old Dec 11th, 17, 06:24 AM
Darin
ilikeike's Avatar
Re: Multi Spring upgrade
If all the normal places are out of budget, maybe Rock Auto or JC Whitney springs,then add lowering blocks.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is online now
post #3 of 9 (permalink) Old Dec 11th, 17, 08:21 AM
Vega$69's Avatar
You can look at Heartbeat City show quality 4 leafs.
I used them on mr Z28 this summer. Ride height good along with good ride.
Think about shock selection as well. The gas shocks line KYB yield a harse ride. I used the standard Gabriel replacement shock
DOUG G and 68Tiger like this.
Vega$69 is offline
post #4 of 9 (permalink) Old Dec 11th, 17, 02:36 PM
Dom
x2 Just replaced mine this summer too (same 4 leaf). Heartbeat city is where I purchased mine as well. A bit pricey but OEM correct. They do sell less expensive ones as well. I opted for the factory or assembly line correct multi-leaf-spring. The overall ride did improve from what I had.
1969 Camaro RS, 327ci, TH350 Automatic, Richmond 3:55 12 Bolt Posi, Norwood 11C build date. Recipient of December 2017 Team Camaro ROTM.
68Tiger is offline
post #5 of 9 (permalink) Old Dec 11th, 17, 04:09 PM
I went with the 4 leaf JRS springs from JCWhitney...and I will agree with the KYB's being harsh, and also I would get some adjustable shocks to dial in the ride you like Vs. swapping a bunch. (More $$ now Vs. even more $$$ later)
68 Camaro~LSx ~all motor
post #6 of 9 (permalink) Old Dec 12th, 17, 06:31 AM
Give Mike at Detroit Eaton Spring a call. He's very knowledgeable and will probably ask you to measure the distance between the top of the axle and the frame rail right above it. There's a range like 5-1/2" to 6" that may be the stock height... I forget right now. Also tell him what size tires/wheels you're running, although the key there is the overall OD of the mounted tire. You can also measure from the ground to the inside tangent of the wheel arch trim as well as from the center of the axle/rim to that point. From what he told me, DES can make you a spring pack that give you the ride and ride height you want. Might be less than Hotchkis too, not sure. Worth a call though.
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #7 of 9 (permalink) Old Dec 13th, 17, 06:32 AM Thread Starter
Good idea. Iím gonna call him. I didnít want to sound like I was pinching pennyís here but just donít want to spend more then is needed. Having said that I also donít want to make an expensive mistake. When in doubt ask the question I was always told. Thanks
68Tiger likes this.
post #8 of 9 (permalink) Old Dec 14th, 17, 11:44 AM
David Pozzi
davidpozzi's Avatar
You haven't given any info on how you want to use your car. Is performance important? Are you wanting to prevent wheel hop? Or is this just for crusing around?
davidpozzi is offline
post #9 of 9 (permalink) Old Dec 16th, 17, 07:39 AM
I Agree with Dave... you have to decide how your car is going to be used. If its just the low-slung pro-touring "look" your after... thats one thing. If you intend to autocross it, thats another, and if you intend to drag race, ditto. If you want everything... yikes! LOL... But I'm sure there's a compromise spring pack out there.
57vette is offline
