Thinking of Converting to Disc Brakes - Team Camaro Tech
 8Likes
post #1 of 38 (permalink) Old Dec 18th, 17, 12:51 PM Thread Starter
Abraham
Have had my 67 for a few month now and love it. I would say one thing I have been a bit hesitant with is the brakes. I have power drums, which I believe came with the car originally (I suspect brakes were replaced when the car was restored, but that was two owners ago I believe).
I have had to make a few hard stops, and the stopping distance is much longer than I am used to. Given the LA traffic and crazy drivers / cyclists here seems like it would be much safer to have a shorter stopping distance.
I would like to convert the front brakes to disc brakes. Couple of questions for the folks here:
1- I believe converting just the front will make a big difference, and that the expense of doing the rears isn't worth it (particularly since I won't be doing the labor myself). Anyone agree / disagree?
2 - From a value standpoint, wondering whether putting disc brakes (when car didn't originally come with them) would detract from value? I don't have the original motor, so my guess is I'm already not in the "as original" category for value, and that it wouldn't be a net negative to have disc brakes, but wanted to see what people thought.
Thanks!
HAMBO
1967 Bolero Red Convertible SS/RS
2013 Ashen Gray Metallic Supercharged SS/RS
HAMBO is offline
post #2 of 38 (permalink) Old Dec 18th, 17, 03:16 PM
Re: Thinking of Converting to Disc Brakes
Unless you have a super rare car, which it sounds like
you don't, changing to front disc is a great upgrade.
HAMBO likes this.
my 67' build thread:
allanjs is online now
post #3 of 38 (permalink) Old Dec 18th, 17, 03:25 PM
DjD
DjD's Avatar
Did you loose track of this thread where you were asking about disc's?
https://www.camaros.net/forums/16-bra...rsion-kit.html
...Dennis
DjD is offline
post #4 of 38 (permalink) Old Dec 18th, 17, 04:13 PM Thread Starter
Abraham
Nope! Sorry, could have probably combined all into one, but that thread was to try to figure out how much time / labor / cost it would take. Having gotten the helpful replies there, this post was meant to ask some additional questions on usefulness and value.
HAMBO is offline
post #5 of 38 (permalink) Old Dec 18th, 17, 05:26 PM
Mickey
Moonpie's Avatar
Best upgrade you can make.
There is another option for rear brakes. I installed 11x2 drum brakes in place of the 9 1/2 stock brakes. Really complements the front discs.
Get the backing plates from an El Camino, and a couple other suspects, and all the parts can be gotten at Auto Reilly.
Moonpie is offline
post #6 of 38 (permalink) Old Dec 18th, 17, 05:39 PM
Went from manual 4-wheel drum brakes to power disc/drum brakes......WWWWAAAAYYYY better stopping.
But I doubt it will ever stop as good as a new car with ABS and such....50 years makes a big difference, that is unless you want to really lay down some $$$$
68 Camaro~LSx ~all motor
post #7 of 38 (permalink) Old Dec 18th, 17, 06:45 PM
Chris
Great idea, just make sure you get all the right pieces including disc/drum MC, correct proportioning valve etc. You should keep all the old parts so if you or someone else wants to return the car to its original state at a later date it can be accomplished with the original parts.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #8 of 38 (permalink) Old Dec 18th, 17, 08:28 PM
Larry
I converted my 67 from 4 wheel manual drum brakes to 4 wheel power disc brakes about 20 years ago. The car stops on a *proverbial* dime now.
I'd have to go look at the spec info to be certain, but it was a kit utilizing (seat of the pants memory here) something like 72 Monte Carlo fronts and 78 Cadillac Seville rear and a Corvette master cylinder and power booster and a proper proportioning valve for the application. It's all factory GM stuff available at any parts store.
I think the cost for the kit was about $1,200.00 and I installed it all myself.
It was an eye opener when I realized how far behind the times those factory brakes were.
It seems we lose sight of how much technology has advanced until we are thrust back into the olden days driving these cars. It doesn't take too many occurrences of all the modern cars right there in front of us with brake lights blaring in our faces ... and we are forced to contemplate using the barrow pit to avoid occupying the same space.
Been there and done that.
I can't complain, but sometimes I still do.
Larry Madsen is offline
post #9 of 38 (permalink) Old Dec 18th, 17, 09:47 PM Thread Starter
Abraham
Thanks for the input, sounds like a worthwhile upgrade.
I found this kit, which seems to have what I would need and I believe would fit my existing wheels:
https://www.getdiscbrakes.com/afxdc14
Anyone familiar with it or recommend something else?
Thanks!
HAMBO is offline
post #10 of 38 (permalink) Old Dec 19th, 17, 05:56 AM
Brett
I clicked on your link and checked "Applications". It did not show Camaro's. My concern is the comment made earlier about the cutting the drum spindle anchor bolt boss .610" mentioned in your other post. From those two clues, I would feel better buying a kit with spindles. This one is not much more than the one you found and it's still the same manufacturer:
Disc brake conversion with spindles
I was able to look into the instructions on the part number you have and it appears that they have made provisions for it to work on your car, but If I were you, I would definitely confirm that.
Brett....
1969 SS 396 X66 - RS Conversion - TKO600 - 3.73 Posi - Paint Code 71-LeMans Blue
Brettallen59 is offline
post #11 of 38 (permalink) Old Dec 19th, 17, 06:29 AM
Darin
ilikeike's Avatar
When you find the brakes you want, since you are already right there swapping a spindle, if needed, it's a good time to throw a rebuild kit on the front suspension and steering components. Basic rebuild kits from PST aren't too bad in the $200-$300 range. maybe even rock auto or Summit...
https://p-s-t.com/i-23160034-polygra...model%3DCAMARO
HAMBO likes this.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is online now
post #12 of 38 (permalink) Old Dec 19th, 17, 06:38 AM
Lyle
I purchased the right stuff kit designed for use with the stock drum spindles a couple of years ago. They have milled an indent on the caliper bracket to accommodate the drum spindles boss without needing to cut it off. I also believe that the discs are slightly smaller diameter to allow for the use with stock steel 14" wheels instead of just the ones originally designed for discs.
It is a simple to install alternative designed to fit stock components but you do not get the BIG BRAKE upgrade with that kit, it's very suitable for street use.
HAMBO likes this.
thebat is offline
post #13 of 38 (permalink) Old Dec 19th, 17, 08:10 AM Thread Starter
Abraham
Brett....
Thanks!! That kit looks like it would have everything I'd need.
HAMBO is offline
post #14 of 38 (permalink) Old Dec 19th, 17, 02:49 PM
David Pozzi
davidpozzi's Avatar
Something to think about:
67 Camaros came with Four piston Discs as an option. Do you want your 67 to look like a stock 67 with the disc brake option or do you want to have aftermarket brakes, OR 1969 single piston discs?
Many aftermarket kits use non-GM parts, some use "Metric" front calipers from the late 70's - 80's. They have a smaller piston, 2 3/4" diameter. 1969 used a single 2 15/16" dia piston. 1967 used a four piston caliper.
Metric: https://www.speedwaymotors.com/1978-...xoCPs0QAvD_BwE
69: Proper "V back" caliper: https://www.classicindustries.com/sh...akes/calipers/
67 four piston: https://www.rickscamaros.com/camaro-...xoCAacQAvD_BwE
Rotors:
67-69 used a two piece hub/rotor. The 67/68 four piston caliper needs extra clearance to the hub so this rotor is needed or there is a special single piece rotor with smaller hub area to clear. A 69 single piston brakes came with the two piece rotor but doesn't need the clearance. The four piston 67/68 calipers need special wheels, not all rally wheels clear them.
Wheel Backspace
Disc brakes will move your current wheels out aprox 1/2" due to differences in the wheel flange location. Watch out for tire clearance to the fenders.
I would NOT install rear discs without Positraction. Disc require no to very limited end play on the axles. Stock open diff rear axles have a huge amount of axle end play. Positraction units have very little when new, but the end play grows with age and wear. They can be re-shimmed. Floating calipers can function with a little end play but not an open diff. Fixed calipers like 4 or 6 piston don't work well at all even with Positraction, they require a floating axle.
ctcz28 and HAMBO like this.
davidpozzi is offline
post #15 of 38 (permalink) Old Dec 19th, 17, 03:58 PM
Brett
Rotors:
Wheel Backspace
David, this is great information that I have not heard of before. Great knowledge for how someone can plan a build or upgrade. I will use this information to decide how I proceed for sure. Thanks!
Brett....
