LS3 holley power steering valve - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 21st, 17, 02:39 PM Thread Starter
DT
Donny
DT's Avatar
Anyone know the install sequence of parts when changing the Holley power steering pump valve to the Earls Corvette adapter ?? The spring flew out with the valve when I was taking it off. Does the spring goes first, than the small valve, than the earls fitting ?? Thx.
DT is offline
post #2 of 5 (permalink) Old Dec 21st, 17, 03:25 PM
Chris
130fe's Avatar
Smile Re: LS3 holley power steering valve
Donny, hopefully this helps you. Yes, spring, then small valve then conversion fitting.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #3 of 5 (permalink) Old Dec 21st, 17, 03:48 PM Thread Starter
DT
Donny
DT's Avatar
Oh man Chris thx. I called Holley and the guy on the phone tells me the valve filter faces you when you look in the hole where fitting goes in. I go into garage and begin install. Holley calls me back at home 5 min later and states he had it backwards! Now I cant get the valve out. HS.
DT is offline
post #4 of 5 (permalink) Old Dec 22nd, 17, 12:35 PM
David Pozzi
davidpozzi's Avatar
use a magnet, if it's an aluminum pressure valve, then blow air in there and it'll pop out.
davidpozzi is offline
post #5 of 5 (permalink) Old Dec 22nd, 17, 01:16 PM Thread Starter
DT
Donny
DT's Avatar
Thank you again David. I tried a magnet (powerful too) and it didn't work. Air, nothing. I finally was able to remove it using a crab claw tool.
DT is offline
