coverting to front dics--power or manual? - Team Camaro Tech
 8Likes
  • 1 Post By Brettallen59
  • 1 Post By ctcz28
  • 1 Post By 57vette
  • 1 Post By rp930
  • 1 Post By ilikeike
  • 1 Post By Moonpie
  • 1 Post By kookykrispy
  • 1 Post By X-77 keith
post #1 of 15 (permalink) Old Dec 26th, 17, 12:38 PM Thread Starter
Keith
Planning a conversion in the spring to front disc brakes...
My motor only makes 9" of Vac at idle, and has tall, slant edge valve covers (full roller rocker setup)...
Is 9" enough vac to run power brakes?
If so, will a "stock" booster work, or will I have to go with a 8 or 9" booster.
Would prefer to go power, but if it'll be a hassle, I'm good with staying manual--the discs will still make a world of difference.
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #2 of 15 (permalink) Old Dec 26th, 17, 12:52 PM
Brett
Re: coverting to front dics--power or manual?
I have 7" vacuum. I have roller rockers/lifters in a 396BB. I added a vacuum pump with a canister and seems to work fine, although I have had other issues that have prevented me from driving it. I think it was a bad Master Cylinder. I installed an 8" booster. that with the surprisingly quiet vacuum pump give me power brakes without engine vacuum.
Brett.......
keithl1967 likes this.
1969 SS 396 X66 - RS Conversion - TKO600 - 3.73 Posi - Paint Code 71-LeMans Blue
Brettallen59 is offline
post #3 of 15 (permalink) Old Dec 26th, 17, 12:58 PM Thread Starter
Keith
Yeah...I'd just a soon leave it manual disc, rather than add the cost of a vacuum pump...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #4 of 15 (permalink) Old Dec 26th, 17, 06:10 PM
Chris
My engine idles with 9" Hg and my power brakes work fine (OEM Delco booster).
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #5 of 15 (permalink) Old Dec 27th, 17, 06:28 AM
I'm making about 14" of vacuum with my 454. Was worried about it bc of the CompCam, but it worked out ok. Went from manual drums to power front discs. Used a TuffStuff dual-diaphragm booster to clear my tall valve covers which like yours... have slanted outside contour. Wilwood calipers/master cylinder/proportioning valve, CPP rotors... big improvement in braking. Bc I was running 15" rally wheels I didn't go monster on the rotor/caliper setup. I now run 17" but still have my chrome rally's so I can swap back and forth. If I was autocrossing I would've gone big brakes all the way.
CompCam Extreme Energy XS274S: Solid Lifters: 0.568" Intake/0.578 Exhaust
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #6 of 15 (permalink) Old Dec 27th, 17, 07:39 AM
kevin
383 SB with intake valve lift of .530, exhaust .515
I had to add a vacuum canister to get better quality brakes using the stock 11" booster
I have 4" valve covers no problem there
flat tire is offline
post #7 of 15 (permalink) Old Dec 27th, 17, 08:13 AM
Rick
I have manual front disc. Works great. I didn’t want to risk it with 9” of vacuum.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #8 of 15 (permalink) Old Dec 27th, 17, 08:23 AM
Darin
ilikeike's Avatar
My engine is about 11~12in @ 900rpm 241/247 @.050" 545/565 lift, 110 lobe center
13" discs in front, 11" back
7/8" bore willwood master cylinder, no power assist,it's worked fine for me so far.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #9 of 15 (permalink) Old Dec 27th, 17, 12:27 PM Thread Starter
Keith
Thanks for all of the input...might just stay with manual when I do my conversion...
Or, I might upgrade to power, and if I have issues, just remove the booster...
Will also see what the guys at right stuff have to say about it in the Spring as well (they re always at the carlisle shows)...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #10 of 15 (permalink) Old Dec 27th, 17, 05:38 PM
Mickey
Moonpie's Avatar
I too have manual front discs .If you get the correct bore MC there is no problem and I have had no problems with mine. I haven't tried panic stop testing yet.
I also converted the rear drums to 11x2. This aids in stopping quite a bit.
Moonpie is offline
post #11 of 15 (permalink) Old Dec 27th, 17, 06:14 PM
Bobby
I was thinking of converting my power front disc to manual. I was reading some brake building tech articles and apparently with all the correct components and some pedal geometry mods you can have just as good if not better braking power.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180° Headers
black/black
no radio
Luwi67 is offline
post #12 of 15 (permalink) Old Dec 28th, 17, 10:11 AM Thread Starter
Keith
OK...likely going manual front disc conversion...
What is the "best" kit out there (value-wise)...just looking for standard swap--don't need wilwood, big brakes, etc...just a simple disc swap...
I see kits form right stuff (also could pick up for a likely discount in the spring at Carlisle), CPP, SSBC, and of course all of the resto huses have kits...
any to really avoid?
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #13 of 15 (permalink) Old Dec 29th, 17, 05:21 AM
Kip
IF ... you end up going with power brakes... do yourself a favor and get a 9" dual diaphragm booster...
1967 SSRS
kv67ssrs is offline
post #14 of 15 (permalink) Old Dec 29th, 17, 11:02 AM
Joe
I'm running manual front discs. IMHO, the camaro is so light, you really don't need power boost. Simply upgrading to front discs is a drastic improvement.
I installed the AFX 14" wheel kit from the right stuff. Easy install and worked great. Uses the stock drum brake spindles. I saved more money by calling them and ordering just the rotors and brackets, and sourced everything else myself.
The right stuff AFXWK14 kit utilizes 88-91 Celebrity calipers/pads/hoses, which I got at my local auto or orielly's. Autozone also had a disc/drum master cylinder for '68 Camaro. I used a proportioning valve from a '79 camaro in the salvage yard, and bent my own brake lines. Peicing it together this way took a little more legwork, but cost less than ordering the full right stuff AFXWK14 kit.
The important thing here is that you ask me what kind of car I've got. "I've got a BITCHIN' CAMARO"
'68 350 4 speed
kookykrispy is offline
post #15 of 15 (permalink) Old Dec 29th, 17, 11:58 AM
keith
X-77 keith's Avatar
Suprised no one has mentioned hydro boost. I have done standard disk with and without a booster. Not much difference in just a mild built big block car. I run hydro boost on my big block step side. It doesn't really matter, just don't cut corners. I have never had a issue with the gm factory disk set up. The high dollor stuff has its place, but for the street , I think it is over kill. Just my thoughts not trying to hurt big brake feelings.?
X-77 keith
X-77 keith is offline
