Are Original Calipers Date-Coded? - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 31st, 17, 05:16 PM Thread Starter
Brett
I upgraded my disc brakes to Wilwood two-piston calipers but got to thinking...since my car is a X66 SS396, could my calipers I removed be original? On one caliper there are two cast numbers on it. On the piston area it has an "A" and below that it has; "F8C12" (December of 68?). That would be perfect as my car was built in December 1968. Underneath that is a larger "510" cast into it.
1969 SS 396 X66 - RS Conversion - TKO600 - 3.73 Posi - Paint Code 71-LeMans Blue
Brettallen59 is offline
post #2 of 7 (permalink) Old Dec 31st, 17, 07:44 PM
Re: Are Original Calipers Date-Coded?
Yes, they're date coded. Check out Camaros.Org or just search on this site. The pics here might be gone, I don't know, but the ones on .org are still there. I'd post a pic of mine, but it's a 69 and different from yours.
'69 SS396 X66 L34 08D (8/22/1969) M21 BS
460ci Gen VI 9.75:1
Semper Fi!
HawkX66 is offline
post #3 of 7 (permalink) Old Dec 31st, 17, 08:02 PM Thread Starter
Brett
I looked on the CRG website, but could not locate any date code info on the calipers. It does say that the J50 option was included on SS396 cars, but that's all the info I found.
Brett......
post #4 of 7 (permalink) Old Dec 31st, 17, 08:19 PM
Brett......
I wish I could help you, but normally I'm used to seeing a Julian date. What you posted is obviously a date code, so I'm not sure. Someone will be along that can explain yours. Good luck and Happy New Year.
460ci Gen VI 9.75:1
Semper Fi!
HawkX66 is offline
post #5 of 7 (permalink) Old Dec 31st, 17, 09:18 PM
Michael
My '67 4-piston calibers use the Julian date codes.
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
Mike_S is offline
post #6 of 7 (permalink) Old Jan 1st, 18, 03:14 AM Thread Starter
Brett
I guess that could mean that these aren't original then.
Brett.....
post #7 of 7 (permalink) Old Jan 1st, 18, 04:43 AM
DT
Donny
DT's Avatar
I thought original Camaro calipers were "633" not "510". When I was Researching this I found conflicting info with date codes etc. Many guys mistakingly used the casting #.
DT is offline
