Multi-leaf shock alignment - Team Camaro Tech
 4Likes
post #1 of 17 (permalink) Old Jan 7th, 18, 12:23 AM Thread Starter
Apprentice
daniel
Hey guys, just swapped my mono leaf set up for a multi leaf set up in my 68.
Passenger side is fine, but the driver side shock doesn't want to line up with the lower shock mount hole. I've heard reproduction parts can have issues, I got my shock plates from Classic Industries.
What do you guys think? Try to heat up and bend the ear? Drill the whole straighter? I've been running into issue after issue with this spring swap.
danielisamazing is offline
post #2 of 17 (permalink) Old Jan 7th, 18, 12:26 AM Thread Starter
Apprentice
daniel
Re: Multi-leaf shock alignment
Pictures: https://imgur.com/a/uUD2I
post #3 of 17 (permalink) Old Jan 7th, 18, 05:56 AM
I would try swapping sides. My 69 assembly manual shows two different part numbers, LH/RH. My guess is 68 would be the same.
69 Hugger Orange 396 M20 3:31
BRICO69 is offline
post #4 of 17 (permalink) Old Jan 7th, 18, 08:52 AM
Kevin
sleepsinshed's Avatar
Have you tried using the original shock plates to see how they line up? When I converted from mono to 3-leaf springs I just re-used the the mono spring plates.
Kevin
sleepsinshed is offline
post #5 of 17 (permalink) Old Jan 7th, 18, 09:08 AM
Just out of curiosity... what 3-leaf replacement brand did you guys go with? I'm probably going to change over my rear next year, and depending on whether I find a multi-leaf or a mono leaf 8.5" rear... I think its time to retire my monoleafs although I want to keep my current ride height. From what I understand there's three choices; the JC Whitney 3-pack, the Eaton Detroit Spring 3-pack, and perhaps the Hotchkis... is that a 3 or 4 pack? Also thought about inboard shock relocation plates.
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is online now
post #6 of 17 (permalink) Old Jan 7th, 18, 10:35 AM
Kevin
I used the JC Whitney springs.
Kevin
post #7 of 17 (permalink) Old Jan 7th, 18, 01:11 PM Thread Starter
Apprentice
daniel
The sides should be correct, there's a small hole behind one of the U-bolt holes on each plate for the parking brake cable retainer, and that only goes in one way.
And yes I've tried using the mono-leaf plates, but the lower shock mount was too low and the shocks would top-out after hitting a bump.
And I got my springs from SD Truck Springs.
post #8 of 17 (permalink) Old Jan 7th, 18, 02:22 PM
David Pozzi
davidpozzi's Avatar
Heat and bend the flange straight. I'd remove those pads around the springs, they just get in the way and add flex. Check spring fit to the perch. Most mono leaf perches don't allow the spring to sit flat, they hit on the edges. You can grind the edges of the top leaf more round to fit better. Mono leaf springs are more narrow in the middle.
arocars, Luwi67 and BRICO69 like this.
davidpozzi is offline
post #9 of 17 (permalink) Old Jan 7th, 18, 02:39 PM
Hmmm... wonder how close they are to OEM springs in height? IIRC, Hotchkis has 1.5" and 3" lowering springs, think they are a 4-pack. Oh well... sooner or later I'll probably be going with DES bc they can pretty much tailor the spring to your desired ride height if you want.
Your lower plates look like brand-new... did you just repaint or powder coat them? And they worked fine with the 3-pack? were you happy with the ride height and ride?
post #10 of 17 (permalink) Old Jan 7th, 18, 03:31 PM
Donnie
My spring plates are almost straight with the plate. Bend them down like Dave Pozzi stated and then they should fit. Mine are 5 spring plates.
Camaro Donnie
1969 RS/SS Black 4 Speed Camaro Coupe
390 Gears with 410 CI small block
Camaro Donnie is offline
post #11 of 17 (permalink) Old Jan 7th, 18, 04:44 PM
Listen to David Pozzi! suspension Guru...
BRICO69 is offline
post #12 of 17 (permalink) Old Jan 7th, 18, 05:20 PM Thread Starter
Apprentice
daniel
thanks guys, ill grab some matches and try to bend it
post #13 of 17 (permalink) Old Jan 8th, 18, 05:28 AM
Kevin
I just painted them since they were off the car. They work fine so far with the new springs. The ride height is perfect now. I used to have air shocks to compensate for the mono leaf rear end sag.
Kevin
post #14 of 17 (permalink) Old Jan 8th, 18, 10:59 PM Thread Starter
Apprentice
daniel
you mean the rubber pads right? they're not needed?
post #15 of 17 (permalink) Old Jan 9th, 18, 08:52 AM
Correct, most three-leaf replacement springs do away with pads as spring thickness matches to mono-leaf with pads, or used to in the past, as with JC Whitney springs.
