Coilover install question - Team Camaro Tech
 1Likes
  • 1 Post By Bricks67
post #1 of 8 (permalink) Old Feb 1st, 18, 02:30 PM Thread Starter
Jason
Just installed Speedtech coilovers using stock shock mount on subframe and speed tech upper and lower control arms. After setting ride height I noticed that the frame hole for the shock appears offset. There is only about 1 inch between the frame and the top of shock. Has anyone else had to enlarge the frame hole? See pic for clarification
1967 Pontiac Firebird
LS3 w/ 6 speed
Bricks67 is offline
post #2 of 8 (permalink) Old Feb 1st, 18, 03:21 PM
Vega$69's Avatar
Re: Coilover install question
I think you supposed to clearance the hole per the installation instructions
Vega$69 is offline
post #3 of 8 (permalink) Old Feb 1st, 18, 03:54 PM Thread Starter
Jason
Nothing in install instructions. Would have been nice. Now I get to take it all apart again. Hope this helps the next guy
LS3 w/ 6 speed
Bricks67 is offline
post #4 of 8 (permalink) Old Feb 1st, 18, 04:04 PM
Cycle the suspension without the spring installed on the coilover and see if it actually hits. How low is your ride height?
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #5 of 8 (permalink) Old Feb 3rd, 18, 05:24 AM
Harry
dawg's Avatar
I just installed a set.
tension up the spring and the clearance will become greater.
ride height will increase though. My Viking Coil over install.
434 stroker
US Navy retired
dawg is offline
post #6 of 8 (permalink) Old Feb 8th, 18, 11:05 AM
David Pozzi
davidpozzi's Avatar
The hole needs to be enlarged with large dia shocks & low ride height. I saw a Vintage Trans-Am Camaro with large dia Koni double adjust shocks that had them jammed up into the hole and sticking. The car was sitting crooked after coming in from the track!
davidpozzi is offline
post #7 of 8 (permalink) Old Feb 9th, 18, 06:35 AM
Peter
The DS coilover conversion instructions has content on clearancing the shocks. You could follow that content for this specific procedure.
Pete
69 Camaro
Owner for 33 years
pwentz3l is offline
post #8 of 8 (permalink) Old Feb 9th, 18, 01:03 PM Thread Starter
Jason
Thanks for info guys. I did check clearance when 1st installed. The hole was definitely large enough for shock to fit through, but when adjusted to ride height the hole was offset. Luckily I was able to jack up front end, remove top shock bolt, push down shock rod and get the additional clearance needed with a small die grinder with a high speed cutter bit. Not a bad job after all.
dhutton likes this.
LS3 w/ 6 speed
Bricks67 is offline
