68 front disc caliper bracket question - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 12th, 18, 02:03 AM Thread Starter
Hot69
Ran into a problem when trying to replace my front soft hose onto my 68 front disc calipers... the previous owner had the soft lines bolted directly into the caliper via what I assume is an aftermarket fitting...
I purchased replacement soft lines from classic and realized they donít fit as it seems I need a bracket that attaches to the caliper and an additional hard line that goes into the caliper... hope this makes sense...
I searched classic web site and found the short steel HARD line I need but cannot figure out what the bracket looks like or how its secured to the caliper that marries the soft line to the hard steel line on the caliper it self
Any ideas?
33anchlo is offline
post #2 of 7 (permalink) Old Feb 12th, 18, 04:42 AM
kevin
Re: 68 front disc caliper bracket question
below is the soft line going into the caliper
flat tire is offline
post #3 of 7 (permalink) Old Feb 12th, 18, 07:01 AM
Thank you, George
post #4 of 7 (permalink) Old Feb 12th, 18, 07:23 AM
kevin
Originally Posted by Everett#2390 View Post
Thank you, George
Er, Kevin - Over 40 Thing here - sorry. I'll give you double scoops of ice cream
post #5 of 7 (permalink) Old Feb 12th, 18, 08:23 AM
Nick
Rarerat's Avatar
Factory 4 piston calipers use a short hard line from the hose to the caliper. It sounds like you are looking for these.
https://www.ebay.com/itm/67-68-Camar...RaeGEp&vxp=mtr
Rarerat is offline
post #6 of 7 (permalink) Old Feb 12th, 18, 08:35 AM Thread Starter
Hot69
I think thatís the one! Does it attach using one of the two caliper bolts?
33anchlo is offline
post #7 of 7 (permalink) Old Feb 12th, 18, 10:18 AM Thread Starter
Hot69
Ok I think Iíve figured out what bracket I need and how it attaches... apparently the hard lines come in various sizes so I need to figure out what size I need...
I think after I spend the money to replace all these parts I might be better off upgrading to a braided type line... is anyone running upgraded braided lines from the factory locations to the factory calipers? If so what company makes em?
33anchlo is offline
