67 Mono leaf sagging already - Team Camaro Tech
 1Likes
  • 1 Post By Daral
post #1 of 8 (permalink) Old Feb 19th, 18, 01:16 PM Thread Starter
Daral
I have a 67 SS/RS. I replaced the original mono leaf springs with new mono leafs in 2006 when I restored the car. I wanted to keep the car as stock as possible. Now the drivers side sits about 1.5 inches lower than the passenger side. I think the radius rod is keeping the passenger side at stock height. Could these mono leaf springs be sagging already? If it is the springs, I know I could switch to the JC Whitney multi leafs but what are my options if I want to keep it stock?
Daral (67 RS/SS 350)
Daral is offline
post #2 of 8 (permalink) Old Feb 19th, 18, 03:15 PM
mike
Re: 67 Mono leaf sagging already
How level is the front, sometimes the front springs can sag. Other then that remove the dead body from the trunk.
bigblockragtop is offline
post #3 of 8 (permalink) Old Feb 20th, 18, 06:17 AM Thread Starter
Daral
The front is straight. I will check the trunk..........
Daral is offline
post #4 of 8 (permalink) Old Feb 20th, 18, 07:43 AM
You can install shorty helper springs (looks like you would only do one side). Put a lowering block on the passenger side (lame - but that's what i did to mine after switching to multi leaf). Rearch the one spring. Shove the dead body to one side and put down the donuts (this is coming from a tubby guy).
I love original, too. It is the cheapest way to survive this hobby. Everyone knows the mono leaf spring is a shortcoming. Everyone that switches to the multi spring worries about the shallow perches. They make stuff for that. I've learned that crooked stances are not uncommon, but mine drove me nuts!
I'm hope we rally your enthusiasm to tackle it and tell us what you did!
Oh yeah... if the thread stays alive long enough, someone might argue that some variety of air shock could lift it! - Scott
68 Camaro Convertible Turbo Thrift 250 Powerglide
63 Pontiac Catalina 389 Roto Hydromatic
84 Chrysler Lebaron Convertible
BlueRibbon is offline
post #5 of 8 (permalink) Old Feb 20th, 18, 08:18 AM
Kevin
KevinW's Avatar
I had good luck with re-arching original GM springs, been many years now and less than 1/2" drop in height. Not sure of newer monos have the same lack of sag.
Kevin
KevinW is offline
post #6 of 8 (permalink) Old Feb 20th, 18, 11:55 AM Thread Starter
Daral
The original GM monos were cracked at the front eye so I couldn't re-arch them. The replacements I put on 11 years ago now were from Eaton and seemed to hold up well until last year. The crooked stance drives me crazy too. I think the radius rod is holding up the passenger side. I could unhook it so see if that evens out the stance but that isn't a fix so new springs are a must.
The JC Whitney 3 leafs don't seem to be available anymore so what multi-leaf conversions are being used now? I found a 4-leaf and 5-leaf that say they will work on a 67 without lowering it. I assume I will also need the Detroit Speed conversion kit as well. Any recommendations?
Daral is offline
post #7 of 8 (permalink) Old Feb 20th, 18, 12:15 PM
I'm always terrified when I post about stuff like this because I know there are plenty of guys on here that have climbed this mountain more times than me! I just hope that they can't stand it and will keep us straight. That being said, a quick search in the forum on this topic will amuse you for a long time. Those 3 leaf springs are still available somewhere. They tell you that you can use your existing perches, but when you see the gap between the shock plate it is disturbing! The kit you will need will include the lengthened U-bolts, some type of pads and the all-important spacers. Be prepared to throw the rubber pads away, drill the shock plate centering holes to a larger size and wonder if you couldn't have made those expensive spacers yourself!
Stand back and admire your work - try to remember if you torqued everything back correctly - and wonder if the back end is just a little too high!
post #8 of 8 (permalink) Old Feb 20th, 18, 01:19 PM Thread Starter
Daral
Like all of us, it will eventually sag with old age.
bigblockragtop likes this.
Daral is offline
