alignment specs - Team Camaro Tech
 1Likes
  • 1 Post By slazisme
post #1 of 7 (permalink) Old Mar 17th, 18, 02:50 PM Thread Starter
Keith
alignment specs
So...what are the best recommended front aligment specs (that I can provide the shop) for a '67 Camaro with Cooper Cobra radial tires?
Power steering (IROC Box upgrade). Currently drum brakes, but likely to convert his summer to front disc.
Currently manual steering, changing this spring as oon as the weather breaks (hence the question)...
When converting to disc, I will also likely do a front suspension rebuild (stock rubber kit)...
small block 406...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #2 of 7 (permalink) Old Mar 17th, 18, 02:56 PM
Simon
Re: alignment specs
Info taken from Super Chevy article below.
Most Factory Settings
(bias ply tires)
0.5 Negative Camber
0.5 To 1.0 Positive Caster
0.24 Toe-In
Good Street Performance Settings
(radial tires)
0.5 Negative Camber
3.5 TO 4.5 Positive Caster
0.10 Toe-In
Good Autocross Settings
(will need aftermarket components to achieve these settings)
2.5 TO 3.0 Negative Camber
4.0 TO 6.0 Positive Caster
0.0 Toe-In (Big Course)
0.10 Toe-In (Short Course)
Muscle Car Front End Alignment Basics - Super Chevy Magazine
dhutton likes this.
slazisme is offline
post #3 of 7 (permalink) Old Mar 17th, 18, 03:30 PM Thread Starter
Keith
Re: alignment specs
Thanks!
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
post #4 of 7 (permalink) Old Mar 19th, 18, 06:03 AM
Jeff
yellow69RS's Avatar
Re: alignment specs
(bias ply tires)
0.5 Negative Camber
0.24 Toe-In
(radial tires)
0.5 Negative Camber
0.10 Toe-In
I don't know where those specs came from. Yes I see it says Super Chevy magazine but where they got them is beyond me. I worked the alignment rack in 1980 and I never saw a factory setting with negative camber. My info says 1/4 positive +/- 1/2. A better source for performance settings is Dave Pozzi.s site He autocrosses a first gen.
FIRST GEN SUSPENSION
Jeff
yellow69RS is offline
post #5 of 7 (permalink) Old Mar 19th, 18, 06:36 AM
Re: alignment specs
Originally Posted by yellow69RS View Post
I don't know where those specs came from. Yes I see it says Super Chevy magazine but where they got the is beyond me. I worked the alignment rack in 1980 and I never saw a factory setting with negative camber. My info says 1/4 positive +/- 1/2. A better source for performance settings is Dave Pozzi.s site He autocrosses a first gen.
http://www.pozziracing.com/first_gen...gnment%20specs
Jeff
They came from modern knowledge about radial tires and suspension/steering. Original specs are inferior, especially with radial tires. David Pozzi will recommend similar settings.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #6 of 7 (permalink) Old Mar 19th, 18, 06:55 PM
Chris
Re: alignment specs
Check out David Pozzi's specs and other suspension/steering info:
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #7 of 7 (permalink) Old Mar 19th, 18, 11:11 PM
Jeff
yellow69RS's Avatar
Re: alignment specs
Factory specs should be what was published by the factory back in the day IMO and what Super Chevy Quoted came from a bad source (also IMO). I feel David recommends a little more caster in is street performance settings than Super Chevy has published and as noted you will never achieve the highest caster autocross setting on stock factory parts. It might read better in the context of the article they published but the snap shot given here is flawed IMO.
Jeff
