rear brake lines - Team Camaro Tech
 2Likes
  • 1 Post By zboss86
  • 1 Post By slazisme
post #1 of 12 (permalink) Old Mar 19th, 18, 06:18 AM Thread Starter
Shad
zboss86's Avatar
rear brake lines
New rearend housing, new Wilwood brakes with parking brake, question on running brake lines and parking brake lines...
I've run my front brake lines, now I'm running the back. I've been using 3/16" nicop with inverted flares so far. I'm assuming I need to run hard line to the back. Then a flex line for differential travel to the axle housing. There needs to be a T fitting that's mounted to the housing and then hard lines out to the calipers? At least that's what I recall on the old drums...
However, I'd like to have flex lines at the end by the rear calipers so I can change out brake pads and pull the axles easily. Is it uncommon to run flex line all the way down the axles tube from the T? Or is that too much flex line, just curious... Thought it may eliminate a couple joints.
Next, I need parking brake lines from my brakes to my main parking brake cable mount on the rear frame. Wilwood sales a universal for hand brake kit with like a 10' line, so that's out.
Pics below for reference....
Don't make fun of the baby brakes, I needed to be able to fit 15" wheels for the drag strip.
image by zboss86, on Flickr
Here's the location I need the parking brake to run too...
Here's the parking brake style.
My Mistress rebuild...
zboss86 is offline
post #2 of 12 (permalink) Old Mar 19th, 18, 06:24 AM
Re: rear brake lines
I would not run flex the entire length of the rear end. Canít recall ever seeing it done...
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 12 (permalink) Old Mar 19th, 18, 07:33 AM Thread Starter
Shad
zboss86's Avatar
I've seen it on several... I've also seen muffler pipe used as a cage, but it doesn't mean it needs to be done...lol I'll probably use a 12" piece of flex on each end by the calipers.
dhutton likes this.
zboss86 is offline
post #4 of 12 (permalink) Old Mar 19th, 18, 08:03 AM
Simon
I'm going to convert my back brakes to LS1 this spring, I have this cable to utilize with the rest of the factory cables. I haven't done it yet but seems to work out based on the measurements of the stock ones.
Dorman C661107
https://www.rockauto.com/en/moreinfo...=6690904&jsn=3
slazisme is offline
post #5 of 12 (permalink) Old Mar 19th, 18, 08:09 AM Thread Starter
Shad
zboss86's Avatar
Dorman C661107
I used the LS1 brakes upfront and I would have done that in a heartbeat in the rear if the 15" wheel selection wasn't limited. But I do have access to some those factory cables. I may have to go rob them off the parts car next time I'm around my buddy's house to see if they'll work. They both utilize the internal parking brake style.
zboss86 is offline
post #6 of 12 (permalink) Old Mar 19th, 18, 08:18 AM
Simon
Shad, the cables I mentioned are from a Ford F150 truck 2005, I believe the LS1 cables attach from the rear of the car and are longer. Hey whatever works best for you.
zboss86 likes this.
slazisme is offline
post #7 of 12 (permalink) Old Mar 19th, 18, 08:27 AM Thread Starter
Shad
zboss86's Avatar
gotcha, I missed that...
zboss86 is offline
post #8 of 12 (permalink) Old Mar 19th, 18, 09:02 AM
Jonathon
Smitty68's Avatar
Check your pm Shad
68 Resto-Mod in progress..355sbc .350 Trans Rushforth wheels
My Build:
Smitty68 is offline
post #9 of 12 (permalink) Old May 6th, 18, 06:53 AM
Probationer
Ragged69
I am in the middle of the LS1 rear brake swap on my '69 Camaro and read somewhere that you can turn the lever and the internals around on the parking brake lever on on the drivers side; Assuming that you have installed left side backing plates on both sides, in order to make them both pull from the front. I took the mechanism apart, but the lever did not seem to be reversible. Any suggestions? I realize I will loose the use of the star wheel retension clip, but i can overcome that.
vabowtie is offline
post #10 of 12 (permalink) Old May 6th, 18, 07:09 AM
mike
I have the same exact setup, hard line from the master to flex line to a t on the rear and hard from there. 13 years still work fine. I did however use the emergency brake cable and pull handle, was not worried about stock look since my 6 speed zf shifter is offset of original. The brakes are great the emergency brakes hold the car so it doesn't roll during starting but I would not trust them in an emergency.
bigblockragtop is offline
post #11 of 12 (permalink) Old May 6th, 18, 07:37 AM
Andrew
Andrew69's Avatar
This thread has details of the parking brake install of rear LS1 brakes.
https://www.camaros.net/forums/16-bra...-pictures.html
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #12 of 12 (permalink) Old May 6th, 18, 12:40 PM
Probationer
Ragged69
Thanks Andrew
vabowtie is offline
