67 ss changing leaf springs from single to multi - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 25th, 18, 04:54 PM Thread Starter
Tom Anderson
Can you just switch the leaf springs to multi on the rear end even thou the spring perches are for single leaf springs . I want to lower the car and just buy some lowering springs plus I think multi will help with the rear end hop under a hard leave in 1st . What are your guys thoughts ? thanx in advance guys
socal_tom is offline
post #2 of 5 (permalink) Old Mar 25th, 18, 06:57 PM
Probationer
Re: 67 ss changing leaf springs from single to multi
Yes you can switch from mono springs to multi. You need a kit from detroit speed to do it however. It is a bolt on kit and its recommended that you use 5 leaf springs. The cost of the kit is like 110 if I remember right. Call detroit speed and let them know what you are trying to do. They are friendly and knowledgeable.
Smoothdawg is offline
post #3 of 5 (permalink) Old Mar 25th, 18, 08:09 PM Thread Starter
Tom Anderson
Hey thanx for the reply I also just read Hotchkis mays a direct fit spring
post #4 of 5 (permalink) Old Mar 26th, 18, 04:27 AM
Apprentice
Brad
I put the Hotchkis kit on my 69 Camaro that had mono leafs last year and it went on great and seems to work great. The stance with the 1.5Ē drop is really nice. Hereís the link from Summit with the whole kit - nothing else needed.
https://www.summitracing.com/parts/HSS-2407C
Iím fairly new at this so what I donít know is if some of the more experienced guys would take issue with this kit or this approach for converting to multi leaf.
Sent from my iPad using Tapatalk
Brad Keuning is offline
post #5 of 5 (permalink) Old Mar 26th, 18, 08:42 PM Thread Starter
Tom Anderson
Thanx I read that
