69 Camaro power steering pulley - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 2nd, 18, 08:09 AM Thread Starter
Probationer
Charlie
Have an original power steering pump on myy 69 Camaro and I am going to be installing a new pulley. My pulley has the tappered notch in the middle of the hole and it also has the nut. What is the proper way to install the pulley? Some show using a pulley installer, but I believe that is only newer models. Can someone explain the steps for an original old stock pulley? Thanking you in advance.
Charlie
cjparks56 is offline
post #2 of 5 (permalink) Old Sep 2nd, 18, 08:21 AM
keith
X-77 keith's Avatar
Sounds like you do have a 6o pump. If it has a nut and a keyway, just tap it on with a hammer. It should not take much to seat. If re using the nut, I would use a little locktite.
X-77 keith
X-77 keith is online now
post #3 of 5 (permalink) Old Sep 2nd, 18, 08:24 AM Thread Starter
Probationer
Charlie
Re: 69 Camaro power steering pulley
Thank you for the information on the tip.
post #4 of 5 (permalink) Old Sep 2nd, 18, 01:32 PM Thread Starter
Probationer
Charlie
Thought I would let you know that I followed your advice and it worked out great! The pulley is now on and she is running smoothly. Again, thanks.
post #5 of 5 (permalink) Old Sep 2nd, 18, 04:51 PM
keith
X-77 keith's Avatar
Glad to hear it. That's why we are here isn't it?
X-77 keith
