1310 or 1330 Pinion Yoke ? - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 12th, 18, 08:19 AM Thread Starter
Apprentice
Paul
The dust shield on my pinion yoke is rattling. I intend to replace the assembly. However, the yoke appears to be a 1330 style because the universal is strapped with bolts rather than u-bolts as the 1310 yoke is equipped in most instances.
I need to pull the old yoke off and replace it in as short a time as possible and therefor need to have the replacement in hand.
Is there any possibility that a 1310 would use the straps/bolts or should I just go ahead and order in a 1330?
'69 Z28, June '69 assembly
paul
vabeach56wagon is offline
post #2 of 5 (permalink) Old Oct 12th, 18, 08:41 AM
Simon
Re: 1310 or 1330 Pinion Yoke ?
This might help you figure things out with some measurements.
https://www.dennysdriveshaft.com/c82_u_joints.html
slazisme is offline
post #3 of 5 (permalink) Old Oct 12th, 18, 09:40 AM Thread Starter
Apprentice
Paul
Thank you....my best bet would be to order in the 1330 yoke and the combo U-joint...if it's a 1330 in there now, I can reuse the U-joint; if a 1310, I'll have the combo...
paul
post #4 of 5 (permalink) Old Oct 12th, 18, 07:27 PM
RDW
Bob
I just changed the pinion yoke on my 67, the old one had straps and the replacement had u-bolts. Itís a 1310
67 Camaro coupe 327 automatic
78 RS Camaro 350 automatic (sold)
RDW is offline
post #5 of 5 (permalink) Old Oct 13th, 18, 07:03 PM
Bobby
Seems the yoke with the straps has more material supporting the u-joint caps than the yoke with the u-bolts. I went with the strap style when building my 8.5.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180į Headers
black/black
no radio
Luwi67 is offline
