68 Subframe Dilemma - Team Camaro Tech
 1Likes
post #1 of 21 (permalink) Old Nov 3rd, 18, 04:31 PM Thread Starter
Apprentice
68 Subframe Dilemma
I'm in the early stages of restoring my newly acquired 68 coupe and I've just noticed the passenger side firewall frame mounting bracket is bent. The plan is/was to remove the subframe to have it blasted and painted as it's got a fair amount of surface rust. I don't want to redo the front suspension and disc brake conversion and bolt it all to a cruddy looking subframe.
It looks like the frame was pushed back an inch or so on the passenger side as the bracket is clearly out of square.
So....once I have the subframe out, is there a way to see if the balance of the frame is still square? Is this worth trying to fix, or should I look at a replacement? How are the replacements in quality and fit?
Any advice or past experience you can share is greatly appreciated.
Richmond, VA
Daddio65 is offline
post #2 of 21 (permalink) Old Nov 3rd, 18, 06:25 PM
keith
X-77 keith's Avatar
Just look for a used one. One from a68 and up Nova will work. Not very expensive. That said... Almost all of them have some kind of repair needed on the rusty mounts. The rusty mounts are easier to fix than a twisted frame.
X-77 keith
X-77 keith is offline
post #3 of 21 (permalink) Old Nov 4th, 18, 02:44 PM Thread Starter
Apprentice
Re: 68 Subframe Dilemma
Thanks, Keith. My plan is to remove the subframe and try to see if it's compromised anywhere else. I'm just not certain how easy or accurate that can be. Any ideas on how to assess the frame once it's out?
Richmond, VA
Daddio65 is offline
post #4 of 21 (permalink) Old Nov 4th, 18, 03:19 PM
I would take a bunch of pictures with high resolution and post them up or put them into an album that others can look at once the subframe is out.
Without having one right next to yours that is undamaged, maybe do some searches for pictures on the internet and maybe hit some shows to see what turns up.
Maybe too contact a local club and see if anyone else close to you might have a frame out of a car like yours or even in a car that you can look at and if you are lucky enough to find a person locally with his frame out, see if you can take yours over there and lay them side by side for comparison and what you might not see another set of eyes may pick up on something.
There are probably some specs in a shop manual and it may require some homemade measuring device out of some steel or wood to check center to center of holes on things.
I would also look closely at the firewall base mounts to see how they look too.
SOA-Nova is online now
post #5 of 21 (permalink) Old Nov 4th, 18, 05:44 PM
I've been in the collision and restoration business for decades. It is not worth the labor to yank a bent subframe when many straight ones are available. An easy hit like a mildly bent horn is no big deal. Hard hits are not worth the time. Full frame cars are entirely different.
Call for restoration and custom paint scheduling:
Sauron67MM is offline
post #6 of 21 (permalink) Old Nov 5th, 18, 09:14 PM Thread Starter
Apprentice
Thanks for the suggestions. Once the subframe is out, I'll see if I can upload some pictures for feedback. I called around to several junk yards and no one has anything of this vintage, Camaro or Nova. Any suggestions where to locate a used subframe?
Richmond, VA
Daddio65 is offline
post #7 of 21 (permalink) Old Nov 5th, 18, 09:25 PM
Simon
https://dallas.craigslist.org/ndf/pt...723334134.html
https://dallas.craigslist.org/ndf/pt...680709061.html
Shipping might be hard to digest, but at least frames should be rustfree from the climates they're in?
slazisme is offline
post #8 of 21 (permalink) Old Nov 6th, 18, 11:02 PM
David Pozzi
davidpozzi's Avatar
Measure in an "X" pattern from existing frame holes to see if it's square. Measure heights to see if one side is up or down relative to the other.
Measurements below. They are first gen Firebird but the same as Camaro
davidpozzi is offline
post #9 of 21 (permalink) Old Jan 4th, 19, 08:39 PM Thread Starter
Apprentice
Update. I've removed the subframe and stripped everything off sans the motor mount brackets. As previously stated, the passenger side firewall mount is bent down and forward, which seems to indicate the frame shifting towards the rear of the car. When laying the frame on a level concrete floor, it does not lay flat so that tells me it's tweaked to some degree. Depending on how I measure it, the horns have about a 1.5" difference to the floor.
I have a quote for blasting and powder coating for $400, but that is before any repair work on the bracket. Now that I know it's tweaked, I'm leaning towards a getting a reproduction frame. A couple of shops in the area say they have had good luck with OER frames.
Thoughts from those that have been down this road before? I'll post up some pictures if I can figure out how.
Thanks in advance.
Richmond, VA
Daddio65 is offline
post #10 of 21 (permalink) Old Jan 5th, 19, 10:30 AM
I was browsing Craigslist for parts and came across these. Not too terrible
far from you. Just kills me how plentiful parts seem to be near the east coast.
It's tough finding good original parts here in the rust belt.
https://charlotte.craigslist.org/pts/6766799941.html
https://boone.craigslist.org/pts/d/m...785738041.html
my 67' build thread:
allanjs is offline
post #11 of 21 (permalink) Old Jan 6th, 19, 10:59 AM Thread Starter
Apprentice
Thanks, Al. I appreciate you passing those along.
allanjs likes this.
Richmond, VA
Daddio65 is offline
post #12 of 21 (permalink) Old Jan 6th, 19, 12:46 PM
Darin
ilikeike's Avatar
Lots of guys pulling out stock subframes to upgrade. Maybe try Pro tour or Lat G forums, you might find one with all the goodies on already.
I wish I was ready to change my stock one out, I'd sell you a real nice one. I found mine on craigslist for $300 3~4yrs ago.
My original one was beat up, sold it as a complete roller with stock style discs for $300.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #13 of 21 (permalink) Old Jan 6th, 19, 01:01 PM
Tim
I believe the factory chassis manual (or the assembly manual - can't remember which) has some very specific measurements and reference points you can refer to as well if you can get the frame up and level so you can measure different aspects. Just one more way to confirm what might be tweaked. The fact it doesn't set flat is not good.
1969 Camaro - a gift from the brother-in-law build thread
Shannon4570 is offline
post #14 of 21 (permalink) Old Jan 7th, 19, 02:41 AM
David Pozzi
davidpozzi's Avatar
An aftermarket front sub (not OER) will give you 2.5” of extra tire room. If that’s in your budget.
post #15 of 21 (permalink) Old Jan 7th, 19, 05:43 AM
Greg
pittpens24's Avatar
X2 - If you are pulling out your sub-frame, definitely look into an aftermarket and price it out. You are wanting to do a brake upgrade and suspension anyway. Depending on the how far you want to go with the upgrades, an aftermarket with all the goodies may not be too far off when all is said and done.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
