67 Hard to steer at first - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 10th, 19, 08:20 AM Thread Starter
Apprentice
Brent
I just winterized my 67 396 with power steering. Before taking the car to the gas station and for its last right I noticed upon start up and the first time turning the steering wheel it was very tight and almost bound up eventually with more effort the wheel turned and then was turning freely as normal with no noises or sounds. The car was put together by a shop in CT seemingly on a specific budget. It was a 350/powerglide now a 396/Muncie M20. Not sure exactly what I am looking for I am 30 and did not grow up with classics at all. Do we have a difference in steering boxes SBC vs BBC? Etc.
Brent396 is offline
post #2 of 4 (permalink) Old Jan 10th, 19, 12:32 PM
Re: 67 Hard to steer at first
See if your power steering pump belt is slipping
3d cad is offline
post #3 of 4 (permalink) Old Jan 10th, 19, 03:39 PM
David Pozzi
davidpozzi's Avatar
Belt tension and condition is always a consideration. If it get's contaminated with oil it will slip. There is a flow control valve in the outlet that may stick if a tiny shaving lodges in just the right place. A filter in the return line is a good idea. PS systems don't have filters built in so any spec of debris causes trouble.
davidpozzi is offline
post #4 of 4 (permalink) Old Jan 11th, 19, 01:34 PM Thread Starter
Apprentice
Brent
Thank you guys. I will check these. Also I am pretty sure its a pontiac pump in there.
Brent396 is offline
