69 Steering Column - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 28th, 19, 08:50 AM Thread Starter
Bruce
69 Steering Column
The threads on my 69 steering column, for the steering wheel retaining nut are messed up beyond repair.
I am installing a quick release steering wheel hub and have no threads for the nut.
Option 1 is to just weld the hub adapter to the original shaft.
Option 2 is to get a new upper shaft.
How hard is it to install a new upper shaft?
Thank you
69 Camaro, 496, 10.34 @ 134.77 mph.
bruce69camaro is offline
post #2 of 12 (permalink) Old Jan 28th, 19, 10:36 AM
Vega$69's Avatar
Re: 69 Steering Column
Fixed or tilt column?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 12 (permalink) Old Jan 28th, 19, 10:37 AM Thread Starter
Bruce
Sorry, for got to add non-tilt or fixed....whichever you prefer...LOL
post #4 of 12 (permalink) Old Jan 28th, 19, 11:22 AM
Vega$69's Avatar
I ask because the degree of difficulty in replacing the part is harder with a tilt.
I would try to thread the existing shaft to the next smaller nut size.
Also if non tilt it might be easier and not expensive to get another column. If not tilt you may want consider upgrading to a tilt.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #5 of 12 (permalink) Old Jan 28th, 19, 12:15 PM Thread Starter
Bruce
This is a track only car, so no tilt is needed.
I have thought about locating a used steering column, but the way things are looking, it may just be easier to remove the column and weld the hub adapter to the shaft.
post #6 of 12 (permalink) Old Jan 28th, 19, 01:08 PM
Kevin
KevinW's Avatar
Bruce, you close to NJ?
Kevin
KevinW is offline
post #7 of 12 (permalink) Old Jan 28th, 19, 01:53 PM
Steven
stamatisg1977's Avatar
my original 69 fixed column im not using. i can pull the shaft its not hard to do and if its good i will send it to you
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is online now
post #8 of 12 (permalink) Old Jan 29th, 19, 03:59 AM Thread Starter
Bruce
I'm in central PA, and it takes us like 3 hours to get to a relatives house in upper NJ.
I never worked on a steering column, except for pulling one out.
When you say it's not hard to do, what is involved (special tools, seals, etc...) in doing this job?
I prefer not having to weld this adapter on, just in case it ever needs to come apart, but I will if needed.
Thanks guys.
post #9 of 12 (permalink) Old Jan 29th, 19, 05:44 AM
Kevin
KevinW's Avatar
Thanks guys.
3 hours is a bit far. I have a column all apart that might be able to help you. The part with the threads is a 2 part collapsible shaft. I do not think you can just replace the upper part of the shaft, probably have to replace the whole shaft. But to do that you are basically taking it completely apart and putting it back together (like a rebuild). Its not hard to do, only a couple hours if you know what you are doing (but could take many days if you have never done it and want to paint and make it pretty! ) . There are bearings (upper, lower) that you should clean and repack (like front wheel bearings). Other then that it is all just making sure the parts go back together in the right order.
Jim Shea's steering pages should help. It has diagrams and repair guides Jim Shea?s Steering Papers Chevrolet A, B & F-Car 1969-1976 Std Columns
Kevin
KevinW is offline
post #10 of 12 (permalink) Old Jan 29th, 19, 06:22 AM Thread Starter
Bruce
Thanks Kevin, that's some very helpful information.
post #11 of 12 (permalink) Old Jan 29th, 19, 07:37 AM
Steven
Not hard really it should slide right out from the bottom once the retaining nut is off
Tremec TKO 600
post #12 of 12 (permalink) Old Jan 29th, 19, 04:09 PM
Steven
Hey bruce here is the shaft from my column
ID:	224385   Click image for larger version
ID:	224387   Click image for larger version
Tremec TKO 600
69 power steering box - o-rings at box end of hoses? Gleason Camaro Tech 0 Sep 26th, 18 09:37 PM
Tilt steering column with Deluxe wheel thewebb1 Brakes, Suspension & Steering 18 Jul 30th, 18 05:53 PM
69 Column Needed Bigfish45 Brakes, Suspension & Steering 8 Jul 3rd, 18 10:16 AM
Steering column rebuild nonac Brakes, Suspension & Steering 0 Feb 12th, 18 10:09 PM
'69 Rosewood Steering Wheel John68F Interiors 3 Dec 4th, 17 10:47 AM
