67 Camaro sub frame - Team Camaro Tech
 1Likes
  • 1 Post By davidpozzi
post #1 of 6 (permalink) Old Feb 7th, 19, 06:44 AM Thread Starter
Probationer
67 Camaro sub frame
I have a 68 Nova that I'm redoing but it doesn't have a sub frame. I was told that a Camaro sub frame and a Nova sub frame is the same. I found a sub frame but it's of a 67 Camaro. Is it possible to use this on my 68 Nova? If not what is the difference between a 67 and a 68 sub frame?
Briguy13 is offline
post #2 of 6 (permalink) Old Feb 7th, 19, 07:16 AM
Darin
ilikeike's Avatar
Re: 67 Camaro sub frame
These are the deals I'd look for.
https://www.pro-touring.com/threads/...Dse-components
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is online now
post #3 of 6 (permalink) Old Feb 7th, 19, 07:32 AM
Will interchange with only small variations in bumper mount holes, if any. A little google time will get you a ton of information.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #4 of 6 (permalink) Old Feb 7th, 19, 05:16 PM
David Pozzi
davidpozzi's Avatar
Later subs had more holes for the front radiator support. 67 has one, 69 has three. Very early 67 frames had no large holes in the inner frame "horn" sections. May have been used for tow hook or tie downs. Early 67 subs did not have the TH400 crossmember mounting holes with narrower spacing. Big block used the TH400 and was not an option till mid-67. 67's have the bump stop to the rear of the lower A arm, its on the subframe bolted to a bracket. 68's had the bump stop to the rear but bumpstop was bolted to the A arm with just a pad on the sub.
jcor12 likes this.
davidpozzi is offline
post #5 of 6 (permalink) Old Feb 7th, 19, 06:34 PM
So are you saying it won’t interchange?
post #6 of 6 (permalink) Old Feb 9th, 19, 05:31 PM
David Pozzi
davidpozzi's Avatar
It will interchange if you do a couple of mods:
Your Nova may need a different hole added for the radiator support on each side. I don't know for sure but it's not a big deal. You can drill new ones. The rest is minor. You'd probably have to do something to make your bump stops work. They are in the same location 67/68, but the rubber part is bolted on the side of the spring pocket on a 67.
So it depends on if you are up to possibly drilling new holes for your radiator support.
Is a 67 Firebird rear seat the same as 67 Camaro deluxe 68resto Interiors 2 Nov 14th, 18 08:32 PM
Vintage Air in non OE AC 67 Camaro Bill Bergen Heating & Cooling 9 Sep 6th, 18 06:59 PM
67 Camaro - mini tubs installed, BMR torque arms does fit perfect sargent Brakes, Suspension & Steering 2 Jun 5th, 18 12:35 PM
