67 Conv rear shocks - Team Camaro Tech
 1Likes
  • 1 Post By dc7432
post #1 of 5 (permalink) Old Mar 5th, 19, 06:58 AM Thread Starter
Dale
67 Conv rear shocks
I purchases new rear KYB Excel gas shocks (KYB343135) and they are short by 2". Top is bolted in and I have a gap at the bottom. I plan on loosing the rear suspension and bouncing on car to see if that helps but the shock will be fully extended. The car is a convertible with stock mono leafs, any thoughts on why thanks in advance.
dc7432 is offline
post #2 of 5 (permalink) Old Mar 5th, 19, 01:38 PM
Re: 67 Conv rear shocks
Did you put in some really heavy duty, or re-arched, leaf springs? Should work fine.
Have any pictures?
'68 Convertible, #'s Matching, 327/210HP
LeMans Blue - Deluxe Parchment Interior
Power Steering, Powerglide, 10-Bolt, 2.73:1
Norwood car, Build date 03D
'53 Ford Crestline - Hardtop
Raven Black/Sungate Ivory
239 Flathead V-8
53Crestline is offline
post #3 of 5 (permalink) Old Mar 5th, 19, 03:50 PM
I used the same shocks (same mdl#) on my 67 with monoleafs. The only issue I had was having to use the old hardware for the bottom mount.
Old Dad's 67 is offline
post #4 of 5 (permalink) Old Mar 5th, 19, 06:17 PM Thread Starter
Dale
All set, both shocks were "stuck" so I gently prayed them down and they extended to where I needed them.
53Crestline likes this.
dc7432 is offline
post #5 of 5 (permalink) Old Mar 5th, 19, 06:47 PM
DjD
DjD's Avatar
Every 1st gen I have ever worked on the rear shocks seemed too short. I assume the body is on jack stands and the tires are hanging on the suspension. Put a floor jack under the diff and jack the rear end up until the shocks line up...
...Dennis
DjD is offline
Rear pinion snubber 67 camaro Heavychevy67 Body Shop 3 Feb 10th, 19 04:55 PM
Is a 67 Firebird rear seat the same as 67 Camaro deluxe 68resto Interiors 2 Nov 14th, 18 08:32 PM
67 rear mono leaf bucko Brakes, Suspension & Steering 16 Oct 8th, 18 01:43 PM
67 Conv Rear Seat Brace install manycj Body Shop 5 Jan 18th, 18 03:19 PM
