98-02 f body brake question - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 22nd, 19, 09:46 AM Thread Starter
Bryan Hall
I know this has been a common swap. I have the brakes installed along with my new booster and Mc. Also have the flex hoses from Tobin at kore3 installed. What are guys using as far and lines and prop valve. Inline tube and the right stuff both said all there lines are factory style for either there prop valve or the factory one.
My car pics...
dallas car show pics plus some of the cars i am building at work
importkiller69ss is offline
post #2 of 4 (permalink) Old Mar 22nd, 19, 10:47 AM
Andrew
Andrew69's Avatar
Re: 98-02 f body brake question
I used the 4-wheel disc 1" bore master cylinder from a same era Corvette and the stock distribution block/ proportioning valve to route the lines. You don't need the inline adjustable pressure valve.
What's confusing is people calling the distributing block a proportioning valve. But maybe it does first direct the flow to the front.
How Master Cylinders and Proportioning Valves Work
You can see a picture by clicking the link below.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 4 (permalink) Old Mar 22nd, 19, 10:51 AM Thread Starter
Bryan Hall
So you think I would be fine with a stock style kit with the prop valve that they supply
My car pics...
post #4 of 4 (permalink) Old Mar 22nd, 19, 12:02 PM
Andrew
Andrew69's Avatar
I believe that functional it will be okay. But those valves they provide are ugly. Just my humble opinion.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
front parking brake cable question 3d cad Brakes, Suspension & Steering 1 Nov 11th, 18 07:21 AM
Brake line question Cunning69 Brakes, Suspension & Steering 8 Aug 3rd, 18 06:53 AM
rear brake lines zboss86 Brakes, Suspension & Steering 11 May 6th, 18 12:40 PM
Parking brake question 3d cad Pro Touring 15 Apr 26th, 18 04:43 PM
Brake Conversion Question bruce69camaro Brakes, Suspension & Steering 5 Feb 2nd, 18 06:21 AM
