What springs for LQ4 swap? - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 30th, 19, 09:05 AM Thread Starter
Probationer
Mitch
My ‘68 apparently had a very heavy big block in it before I got it. I’m putting in a 6.0L LQ4. Right now there is nothing but the engine and the body on the subframe, but even with my 330 lb self standing on the frame, the springs don’t even start to compress, so obviously they are WAY too stiff. Any idea what springs I should be using? Looking through the NPRD catalog there are a boggling number of options.
Simplemitch is offline
post #2 of 7 (permalink) Old Mar 30th, 19, 11:37 AM
Re: What springs for LQ4 swap?
Spring rates are a function of weight and desired ride quality. You weigh the car (four corner weights are best) to determine the pounds you are going to be applying to the springs (rated in inches of compression per pound). Then figure your ride height by subtracting from the free height of the spring (if you want it two inches lower than stock, compare the spring rate stock and subtract height for difference in your weight).
Big Dave
Larger Dave is offline
post #3 of 7 (permalink) Old Mar 30th, 19, 11:46 AM
I would use Ridetech Streetgrip progressive rate springs.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #4 of 7 (permalink) Old Mar 30th, 19, 11:52 AM
Chris
ckaram's Avatar
When I had my LS swap we went lo-fi and cut a coil out of each. May not be ideal but it worked.
Check my rides:
1968 Camaro Convertible LS1, T56
2016 Challenger RT Scat Pack Shaker
ckaram is offline
post #5 of 7 (permalink) Old Mar 30th, 19, 01:55 PM
Beth
Look through this :
https://www.camaros.net/forums/16-br...mbos-here.html
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #6 of 7 (permalink) Old Apr 25th, 19, 12:09 PM
MCB
MCB Parts
We would normally send a SBC coil for an LS. Depending on brand, typically this will be #450-500lb.
We sell a LOT of Ridetech Streetgrip coils as they are a dual rate coil. While cruising, you are on about a #350 rate and when the coil loads (Cornering) it comes up to about #700lb to keep the car nice and flat. This is truly the best ride you can get out of a first gen, especially when run with their single adjustable shocks!
Let me know if you need further info or prices on them.
MCB
MCB is offline
post #7 of 7 (permalink) Old Apr 25th, 19, 06:34 PM
Didn't measure before and after, but would guess less than ˝" difference using my Moog Z-28 replacement springs with 1 coil cut (before swap)
68 Camaro~LSx ~all motor
Springs, A arms, BB vs SB coil springs ???? Just 1 More Brakes, Suspension & Steering 13 Jan 3rd, 19 11:32 PM
3" Lowering Springs BigHog Brakes, Suspension & Steering 5 Dec 6th, 18 05:49 PM
Front springs: anyone fitted stiffer springs on a BB street car? Miles B Brakes, Suspension & Steering 2 Nov 30th, 18 05:40 PM
Could the leaf springs under my 69 camaro be the wrong ones?? Sam 15 Brakes, Suspension & Steering 9 Mar 3rd, 18 03:06 PM
Don't wait - swap mono leaf for JCW three leaf springs 68DaveV Brakes, Suspension & Steering 203 Jul 7th, 16 08:13 AM
