Installing steering column onto coupler / rag joint - Team Camaro Tech
 2Likes
  • 2 Post By CDB
post #1 of 4 (permalink) Old Mar 30th, 19, 05:44 PM Thread Starter
CDB
Clifton
Any advice for this? Should the rag joint be installed onto the steering column first? Or should I install the rag joint onto the steering shaft first? I tried the latter and I barely have any room to work with, let alone fit a torque wrench in there. My engine bay is fully assembled.
Just looking for advice on the easiest way to get this done or route to take with my unwieldy hands.
1969 power steering, original gear box, tilt column, repro rag joint.
1969 RS/SS 350 3.31 4 Speed (All Original)
CDB is offline
post #2 of 4 (permalink) Old Mar 30th, 19, 06:05 PM
Re: Installing steering column onto coupler / rag joint
If it's like a 67 you'll have to release the steering column and move it towards the inside
of the car for assembly clearance. Install the joint to the steering gear first. Be sure you
time it correctly. There should be a notch milled in the gear shaft that allows the lock bolt
to be inserted. Then slide the column back in and tighten the bolts. Don't be concerned
about using a torque wrench. Just get the nuts tight.
my 67' build thread:
allanjs is offline
post #3 of 4 (permalink) Old Mar 30th, 19, 06:46 PM Thread Starter
CDB
Clifton
The steering column is already completely out. If I don’t have to use a torque wrench (the rag joint box came with different measurements for each bolt to use) then I can probably just use a smaller wrench and be fine. I was worried about fitting a torque wrench down in there.
So I’m just going to install the rag joint, then connect the steering column, and tighten the remaining bolts the best I can.
allanjs and french69ssrs like this.
CDB is offline
post #4 of 4 (permalink) Old Apr 5th, 19, 10:55 AM
Timmy
Hi Clifton
Here is a Post I had Posted to, I did an Upgrade for my P/S Box but also needed to Replace my "Rag Joint" , Has Pics and some Info.
https://www.camaros.net/forums/16-br...joint-pic.html
I bought the one from eBay, I used their 36 Spline at the Box End and the Original "40 Spline 3/4" end from My Steering shaft/ Rag Joint end.
Timmy
1969 SS/RS Coupe 427BB 700R4 12 Bolt 4:11 A/C, High School Resto Mod
November 1968 Build Date
french69ssrs is offline
69 Steering Column bruce69camaro Brakes, Suspension & Steering 11 Jan 29th, 19 04:09 PM
Steering Column replacement Options COCamaro1 Brakes, Suspension & Steering 2 Nov 25th, 18 06:00 PM
Tilt steering column with Deluxe wheel thewebb1 Brakes, Suspension & Steering 18 Jul 30th, 18 05:53 PM
What rag joint do I use for tilt and IROC box? bondora68 Brakes, Suspension & Steering 4 Jul 3rd, 18 08:44 PM
Steering column rebuild nonac Brakes, Suspension & Steering 0 Feb 12th, 18 10:09 PM
