Shock suggestions - Team Camaro Tech
 6Likes
post #1 of 40 (permalink) Old Apr 1st, 19, 05:37 PM Thread Starter
Shock suggestions
67 camaro. 1.5" Ridetech drop front springs. 2" lowering block rear (shock & mono leaf in stock location)
Currently have Edelbrock shocks which came with the car. IDK how many miles on them. Rear is very unforgiving and I feel more "road" through rear than front. IDK if it is because of the lowering block but the ride was basically the same without the blocks
KYB's are cheap...the KG5524 & KG4515
Hotchkis 1.5's are $519 (ouch) for all 4. Can't find info if the fronts are good with a 1.5" drop
RideTech are noted by Pozzi as being his fav....but $185 each
Edelbrock no more as Q1 bought them
I don't drag or AutoX this car. Just looking for good ride quality and street handling
Appreciate comments
SoCal805 is offline
post #2 of 40 (permalink) Old Apr 1st, 19, 06:36 PM
Re: Shock suggestions
I like Bilsteins for a street driven car.
Donít skimp on shocks. They are a major determinant of ride quality.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 40 (permalink) Old Apr 1st, 19, 07:05 PM Thread Starter
I do to, have them on my Impala..
Not seeing rear Bilsteins, just fronts (24-029728). for a "Non" drag shock
Have a part # or x reference for rears??
https://www.bilstein.com/us/en/produ...36162841812792
SoCal805 is offline
post #4 of 40 (permalink) Old Apr 1st, 19, 07:15 PM
Maybe they discontinued them. They used to make Hotchkis shocks before they went with Fox to compete with Ridetech. I would go Ridetech or Hotchkis then.
Bilstein lists rear shocks for 68-69. Not sure why 67 is different. They call out the same drag shocks for 67-69....
dhutton is offline
post #5 of 40 (permalink) Old Apr 1st, 19, 07:19 PM
Simon
Scroll down to the increased handling/ performance category.
https://www.rockauto.com/en/catalog/...+absorber,7556
Plus Rock Auto is a sponsoring vendor on TC, you get a 5% discount.
slazisme is offline
post #6 of 40 (permalink) Old Apr 1st, 19, 07:55 PM
Shocks are a very personal choice IMO....I would go adjustable to get the ride YOU want/like
Up front costs can be high, but changing shocks 3,4,5 times is too.
Look into some ViKings.
DT and bhodgdon400 like this.
68 Camaro~LSx ~all motor
post #7 of 40 (permalink) Old Apr 1st, 19, 07:56 PM Thread Starter
^^^^, thanks...but I have a 67 so no Bilsteins shown for that year. 67 has rear shocks both facing forward so that may be a specific part vs 68-69...but RA shows Bilsteins for 68-69 for rear mono leaf.
Anyone using Bilsteins on 67 mono leaf?
what is the TC rock auto code?
SoCal805 is offline
post #8 of 40 (permalink) Old Apr 1st, 19, 07:58 PM
Then why same Bilstein drag shocks for 67-69? I think same shocks as 68-69 will work on 67....
Ridetech calls out same shocks for 67-69.
dhutton is offline
post #9 of 40 (permalink) Old Apr 1st, 19, 08:36 PM
Jeff
I have the adjustable Hotchkis/Fox with 2Ē drop, no issues and love the ride quality.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
post #10 of 40 (permalink) Old Apr 1st, 19, 09:30 PM
Roger, This should work. If not just Google Rockauto discount.
https://www.retailmenot.com/view/roc...Channel=online
my 67' build thread:
allanjs is offline
post #11 of 40 (permalink) Old Apr 1st, 19, 10:22 PM Thread Starter
From Bilsteins application 411 it would appear their rear shock is only for 68-69. I assume the dual front facing shocks on a 67 are a different length
SoCal805 is offline
post #12 of 40 (permalink) Old Apr 2nd, 19, 07:34 AM
Darin
ilikeike's Avatar
I had brand new KYB, they were terible in my opinion. I removed them almost immediately and bought Ridetech.
I just took my hotchkis 3" drop leaf springs and Ridetech HQ adjustable rear shocks out, maybe 3000mi on shocks.
https://www.ridetech.com/products/sh...ock-hq-series/
I won't give them away, but PM me if your interested.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #13 of 40 (permalink) Old Apr 2nd, 19, 09:44 AM Thread Starter
While Bilsteins site, and Summit also, they don't list the AK2073 for 67, just 68-69. Ricks Camaro lists it for fitting 67-69
I can't find measurement data for it (collapsed and extended length) to compare to what a stock rear shock measures for a 67
So anyone running the Bilstein AK2073 on a 67?
with 2" lowering blocks?? (shock mounted in original position)
SoCal805 is offline
post #14 of 40 (permalink) Old Apr 2nd, 19, 10:38 AM
Lowering blocks do not affect shock length. Pretty sure Bilstein has an error in their listing since as near as I can tell all other shock manufacturers spec same shocks for 67-69. Bilstein also does for their drag shocks....
dhutton is offline
post #15 of 40 (permalink) Old Apr 2nd, 19, 10:58 AM Thread Starter
Yeah Don I suspect the Bilsteins will work for 67 but was hopeful to find specs on collapsed and extended length. Weird Bilstein does not note anything on their site as just about every other brand does. (fully collapsed & extended + piston max travel)
Going to measure the Edelbrocks that are in now. Not sure they were ever the right size but they came on the car. Rear end seems like zero "shock" effect dampening. I will pull bottom bolt to see if there is any resistance left at all in the shock. IIRC when I installed the lowering blocks they did have a good amount of pressure but will check
Noticing rear view mirror image blur from vibration when driving on serrated (grooved) sections of Fwy. Also speaker grills on package tray vibrate lose so something causing vibes in rear. I initially thought DL angle but that has been checked several times. Pinion is 2 1/2 degrees and tranny is 3 degrees so 1/2 degree difference. I can try a thin washer under tranny to bring it = to 2 1/2 degrees but from my understanding 1/2 degree difference between tranny & pinion is fine
SoCal805 is offline
T56 Clutch & Pressure Plate Suggestions? really_n0b0dy Transmission & Driveline 17 Dec 11th, 18 12:28 PM
DSE Shock Plate Installation Nicc21 Brakes, Suspension & Steering 5 Dec 9th, 18 01:18 PM
Multi-leaf shock alignment danielisamazing Brakes, Suspension & Steering 16 Jan 16th, 18 01:27 PM
