Q?: Clutch Pedal Travel - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 9th, 19, 11:40 AM Thread Starter
Fred
77thor's Avatar
Recently replaced the clutch and resurfaced the flywheel on my 69 Camaro 4-speed (M21).
Now the clutch pedal must go a lot lower to the floorboards before engaging.
Is this adjustable? or could I have done something wrong??
Sorry, I intended to post this under the "Transmission & Driveline" topic.
My bad.
77thor is offline
post #2 of 8 (permalink) Old Apr 9th, 19, 11:53 AM
Steven
stamatisg1977's Avatar
Depends on how much was taken off the flywheel when resurfacing.
Did you try adjusting clutch for rod?
May either need a taller throw out bearing or an adjustable fork pivot ball
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 8 (permalink) Old Apr 9th, 19, 12:17 PM
Re: Q?: Clutch Pedal Travel
as noted when you resurface the FW the pedal will drop some. They make shims for FW you put between crank & FW to compensate for thickness taken off FW when resurfaced
SoCal805 is offline
post #4 of 8 (permalink) Old Apr 9th, 19, 01:50 PM Thread Starter
Fred
77thor's Avatar
I haven't tried anything yet.
But, will do.
77thor is offline
post #5 of 8 (permalink) Old Apr 9th, 19, 06:03 PM
scblucam's Avatar
Not an expert, but if you had to surface the flywheel enough to not be able to adjust with the clutch rod you needed a new flywheel.
68 302 M20 - 85 IROC Z
scblucam is offline
post #6 of 8 (permalink) Old Apr 9th, 19, 07:29 PM
Originally Posted by scblucam View Post
not an expert, but if you had to surface the flywheel enough to not be able to adjust with the clutch rod you needed a new flywheel.
69z28302 is offline
post #7 of 8 (permalink) Old Apr 10th, 19, 05:34 AM
Ralph
Your flywheel should be .980 thousands thick measuring from the crank flange surface to the flywheel clutch surface / face. That will give you the proper clutch linkage adjustment baseline. If after a resurface you should always install crank shims as So Cal mentioned to obtain the proper tolerances.
Also be very careful, even if you shim the flywheel, when too much material is removed from the flywheel face there's a chance the clutch springs could contact the crank bolts, if not at first then when the clutch wears the contact will rear its head. GL
thesanz is offline
post #8 of 8 (permalink) Old Apr 10th, 19, 07:20 AM
Steven
I would just get a new flywheel
Tremec TKO 600
67 & 68 clutch fan used a spacer? R66 Heating & Cooling 7 Feb 21st, 19 10:32 AM
clutch problems ken5537 Transmission & Driveline 2 Feb 13th, 19 11:56 AM
T56 Clutch & Pressure Plate Suggestions? really_n0b0dy Transmission & Driveline 17 Dec 11th, 18 12:28 PM
clutch stop for 1969 camaro with tko 600 Buddy z/28 Transmission & Driveline 5 May 28th, 18 05:54 PM
Worn clutch linkage questions daven1256 Transmission & Driveline 12 Apr 25th, 18 07:35 AM
