Steering box header clearance issue - Team Camaro Tech
 5Likes
  • 2 Post By scblucam
  • 1 Post By Everett#2390
  • 1 Post By french69ssrs
  • 1 Post By 57vette
post #1 of 12 (permalink) Old Apr 9th, 19, 07:23 PM Thread Starter
Apprentice
Nick
Howdy. Its been a long time since I've been on the site (kids, work, etc), but I back working on the 69 and ran into a snag.
The car has a BBC 454 in it and its crowding the space for the steering box. I purchased a CP500 to replace the original box. However when I went to install it, I found I was short a good 1/2"-3/4" and needed that much additional space between the frame and header to mount the new box.
Wondering if anyone has had a similar problem, and what solutions yall came up with to keep the big block and have power steering.
Always appreciate the help. S/F.
Waste no more time arguing about what a good man should be. Be one.
-Marcus Aurelius
sphinct03 is offline
post #2 of 12 (permalink) Old Apr 9th, 19, 08:06 PM
scblucam's Avatar
Re: Steering box header clearance issue
Do you have the proper Big Block engine stands and transmission cross member?
buenymayor and DT like this.
68 302 M20 - 85 IROC Z
scblucam is offline
post #3 of 12 (permalink) Old Apr 9th, 19, 08:43 PM
Tom Anderson
I have that steering box and a set of Doug's headers , Things are close but it all fits
socal_tom is offline
post #4 of 12 (permalink) Old Apr 10th, 19, 05:35 AM
Bruce
I have an IROC box with Dynotech headers and a BB. Almost touches. Been that way for 10 yrs.
The Camaro Guy is offline
post #5 of 12 (permalink) Old Apr 10th, 19, 06:00 AM
Frank
My solution was to install the proper big block frame stands/engine mounts, Headman headers and a slight file job on the side of the gear box
'68 Camaro 454, 4sp
Just 1 More is offline
post #6 of 12 (permalink) Old Apr 10th, 19, 06:37 AM Thread Starter
Apprentice
Nick
Thanks for the feedback. I am fairly certain that i replaced the motor mounts with the correct type for a BBC when I pulled the 327 (long time ago). As for the trans X-member, I will have to verify later today. Not sure off the top of my head.
In the event that I am not running the correct motor mounts, would swapping them to the correct type adjust the motor position enough to give me the needed clearance?
Is the Iroc box close to the same size as the stock box?
https://www.ss396.com/camaro/ACE-9412.htm
l - I believe these are the mounts i ordered/installed when i did the engine swap.
Many thanks.
-Marcus Aurelius
post #7 of 12 (permalink) Old Apr 10th, 19, 07:15 AM
DT
Donny
DT's Avatar
Just an FYI BB engines in our Camaros are offset approximately 1/2 inch to the passenger side. Installing the correct motor mounts and trans X-member is crucial when headers are on the car. Measure from the air cleaner rod in carb to passenger fender. I believe you should get 24 inches. I don't have my BB anymore so I can NOT verify the actual measurement. Perhaps someone with a BB can check this for you.
DT is offline
post #8 of 12 (permalink) Old Apr 10th, 19, 07:17 AM
You can run a string from cowl panel center crease to header panel crease and if air cleaner stud/nut is over to the pass side, then yes, correct frme mounts were used.
Keeping driveline angles satisfied, the proper BBC trans crossmember would be needed.
Are boxes same size? Measure with tape measure and maybe, make a model and see if it would fit.
Some earlier installs, say 20 years ago, had to dent tubes for clearance
You could change over to rack-and-pinion steering?
DT likes this.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
post #9 of 12 (permalink) Old Apr 10th, 19, 08:25 AM
Vega$69's Avatar
Good advice on the mounts.
I would strongly suggest not even thinking about R&P with a stock sub.
Vega$69 is offline
post #10 of 12 (permalink) Old Apr 10th, 19, 09:10 AM
Timmy
Hello Nick
I also had Issues with my 427 and Headers for my 69, I made some mistakes and Learned allot.
I wrote this to another T/C Member with a 67, there might be some subtle issues between them but for the most part, Get what you want and What Fits !
- I Only have done 1 Car, My 69 and there are the Experts Here at T/C that have allot more Experience than I, but I did allot of my Own Research and Planning, Mock-up and the Reasons I chose to go the Route I did.
https://www.camaros.net/forums/18-en...gs-d320-r.html
If Nothing else, some Eye Candy and Keep you from making a Mistake.
Be Careful of where your Power Steering Hoses are to your Primary Tubes.
Here is a Link for my Power Steering Hose "Heat Shield"
https://www.camaros.net/forums/18-en...at-shield.html
And a Power Steering Hose Routing Info Link
https://www.camaros.net/forums/16-br...pics-long.html
Timmy
sphinct03 likes this.
1969 SS/RS Coupe 427BB 700R4 12 Bolt 4:11 A/C, High School Resto Mod
November 1968 Build Date
french69ssrs is offline
post #11 of 12 (permalink) Old Apr 10th, 19, 10:14 AM
There's not a lot of room when you put a BBC in a 1st Gen Camaro, so the factory BBC mounts shifts the motor slightly to the passenger's side. That works with cast iron manifolds but many aftermarket headers will give you fits. Some brands come with a factory-slight "dent" where the third primary comes into proximity with the PS box. I've got Hooker Competitions on my car... 2" primaries, 3.5" collector. When we installed them, we added a few Moroso motor mount shims to give it a little extra lift... maybe 1/8"-3/16"? Worked out OK (see pix). They came with the dent. Use a 1" deep socket with a shop towel wrapped around it to tap in a dent if needed. You won't lose any horsepower.
Another option is headers with a different design, but be prepared to pay a bit more. Dougs, Hooker, and Lemon all make headers that have problem tubes sweep up, over, and down.
Hooker Super Competitions
french69ssrs likes this.
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #12 of 12 (permalink) Old Apr 10th, 19, 07:14 PM Thread Starter
Apprentice
Nick
Thank to all of yall for the suggestions. Took a measuring tape and the air cleaner stud is less than 1/8" off center. This leads me to believe that i am not running the correct BBC motor/frame mounts. That being said, I will probably pull the motor when the weather breaks here in CO, put in the new mounts and trans Xmember. Again, thanks for the help. S/F.
-Marcus Aurelius
AGR Variable Steering Box with Long Pitman and Short Arms jorgezee1 Brakes, Suspension & Steering 9 Jul 24th, 19 05:07 PM
Header clearance issue Just 1 More Camaro Tech 17 Feb 27th, 19 05:10 PM
Power Steering Header Clearance bill3337 Camaro Tech 7 Feb 8th, 19 11:24 AM
69 power steering box - o-rings at box end of hoses? Gleason Camaro Tech 0 Sep 26th, 18 09:37 PM
Power steering box adapters zboss86 Brakes, Suspension & Steering 7 Jul 31st, 18 09:01 AM
