Removing power steering lines from steering box - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 11th, 19, 03:08 PM Thread Starter
Jeff
Grifter's Avatar
Hey,
Is there a special tool or trick to removing the power steering lines from the steering box?
I have a '69 396 with exhaust manifolds, I have a set of line wrenches with pivoting heads put there is practically no room to loosen the lines from the box. To get the wrenches on the flare nuts the wrench has to be 90 degrees to the steering box so you can't get any good leverage on the wrench.
Am I supposed to use flare nut attachments with a socket driver or am I supposed to remove the steering box from the car with the lines attached and remove them on the ground while lying under the car?
Jeff
Grifter is offline
post #2 of 2 (permalink) Old Apr 11th, 19, 03:36 PM
Jeff
Re: Removing power steering lines from steering box
That what I use, a crows foot line wrench on a long extension.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
69 power steering box - o-rings at box end of hoses? Gleason Camaro Tech 0 Sep 26th, 18 09:37 PM
Power steering box adapters zboss86 Brakes, Suspension & Steering 7 Jul 31st, 18 09:01 AM
Cardone power steering box X-77 keith Brakes, Suspension & Steering 4 May 21st, 18 06:18 AM
Power steering Box outlet question dawg Brakes, Suspension & Steering 6 Apr 15th, 18 12:44 PM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 10:37 AM
