Ride height issue - Team Camaro Tech
 2Likes
  • 1 Post By dhutton
  • 1 Post By 130fe
post #1 of 12 (permalink) Old Apr 11th, 19, 03:17 PM Thread Starter
Louis
Ride height issue
So I have an ls1 t56 swap and didn't like the gap between the fender and tire so i decided to put some lowering springs hotchkis 2" drop. Stock arms with rebuilt bushings... car is bottoming out on most places. long tube headers doesnt help either. what can i do to have the nice gap taller tires? not sure where to go moving forward... I decided to put original springs back on but long like the gap. what are my options.
RaiderNation67 is offline
post #2 of 12 (permalink) Old Apr 11th, 19, 03:24 PM
Jeff
Grifter's Avatar
Re: Ride height issue
What’s your ride height at the fender lip? I have hotchkis 2” drop springs on my ‘69 without any bottoming out.
Mine is 24 3/4 inches to the chrome fender lip with 225/60/15 tires.
Grifter is offline
post #3 of 12 (permalink) Old Apr 11th, 19, 03:31 PM
What is bottoming out? Headers? Oil pan? What headers, oil pan and mounts do you have?
130fe likes this.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #4 of 12 (permalink) Old Apr 11th, 19, 03:46 PM Thread Starter
Louis
so i tried it with swap with my 2 camaro's 67 & 69
67 bottoms out at muffler, frame, have shorty headers on this one. I cant even slide floor jack was running torque thrust 17 with 225/45/17
69 I can slide floor jack but i would scrape with the long tube headers and cross member for t56 that i modified from a turbo 400 700r cross member. Running 15' rally's 225/60/15 and tried 235/60/15 235 scrapes inner fender when hitting dis. Also with the 69 i took springs out 5 or 6 times and i'm sure the spring is sitting in the hole and the driver side is still lower than the passenger side.
Any help will be very appreciated.
Thank you in advance
post #5 of 12 (permalink) Old Apr 11th, 19, 05:57 PM
Jeff
Grifter's Avatar
My tire sits about 1/2 inch up into the wheel well.
When I talked to Hotchkis they said the fender lip will be just about the top of the tire with a 225/60/15 and a 2 inch drop spring. If yours is up into the wheel well more then that you might have a 3 inch drop spring or maybe a drop spindle you aren't aware of.
Grifter is offline
post #6 of 12 (permalink) Old Apr 11th, 19, 06:36 PM
My 67 also bottomed out with long tube headers. Went to shorty's and was able to tuck the exhaust up nice and tight. Now jut the occasional extra tall speed bump rubs the oil pan.
1967 Camaro
383 stroker
Automatic
Duneit is online now
post #7 of 12 (permalink) Old Apr 11th, 19, 11:08 PM Thread Starter
Louis
I have the hotchkis 19830012 springs I added spacers on each side to rise more, with the 67 installed it raised evenly, when I installed in the 69 camaro driver side sits lower.
67 has shorty's but it hit the frame, pipes/mufflers. I just bought some mog 6308 and Ill see if this ma
69 scrapes at pipes, decided to raise engine by changing the frame mounts to regular sbc 350 as i had 3/4" shorter ones as i went with the lower z28 mounts. we'll see if this may help height as well. Another issue is the driver side is lower than passenger side, will add global west .750 spacers and see if the balance out.
will update what happens and see if this will make things better also replacing my doug headers d3337 to some ebay headers that clears the gear box
post #8 of 12 (permalink) Old Apr 11th, 19, 11:36 PM
Chris
130fe's Avatar
Switch your mounts, crossmember, pan and headers to Holley. Problem solved.
DT likes this.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #9 of 12 (permalink) Old Apr 12th, 19, 08:38 AM Thread Starter
Louis
Chris, forgot to mention while i pulled the motor out I did go ahead and installed my new holley 302-2 pan, I had the ls1 camaro pan in the car and it was so close to the firewall, the holley will be moving it forward 1" but this will cause my driveshalf to be short now. 2010 swap...
the 67 i did the swap in 2008 and had the ls1 pan notched at the time.
post #10 of 12 (permalink) Old Apr 12th, 19, 10:04 AM
Chris
130fe's Avatar
Louis, I hear you. I did my swap in 2010 also and had used the some of the best parts out at the time. I had S&P mounts, auto Kraft pan and stainless works headers. Driving at >60 mph I had a driveline vibration that made it unfun to drive. I mean the rear view mirror would shake so bad I couldn’t see out of it. I put up with it until late last year. I swapped all of my stuff to the newer Holley stuff. Works awesome. No driveline issues, no more leaking oil pan. I even sold my old stuff to recoup some of the $. Drive all day down the interstate at 80 now, love being able to enjoy the car once again.
Chris
130fe is offline
post #11 of 12 (permalink) Old Apr 12th, 19, 10:44 AM Thread Starter
Louis
Chris, the 1st one 67 was done in 08, I drive all the time with the gap like that with tires being 215/45/17 from the beginning till I started meeting with people that were all about pro touring. The notch pan started to leak in 2011 then fixed it by RTVing the spot where the pan was notched still holding up. not going to change the pan on this one as its good. Planning to add vintage air soon as I like to take long trips wit this car. I will insert the new mog 6308 same time i do the a/c setup and i'm not touch the suspension anymore.
For the 69 i'll try and figure out which long tubes will work best for me, from the measurements I'm going to clear at least 3/4". so headers wont scrape and will also install my magnaflows 3" pipes. I'm hoping it clears or these hotchkis will be thrown out, and i'll ride a little higher and wont car about the stance just as long as I can drive the car from SF to LA, without any problems.
Thanks again
Louis
post #12 of 12 (permalink) Old Apr 13th, 19, 05:50 AM
Bruce
Sometimes we have to realize aftermarket changes don't always work out the way we like. Unless you want to throw a bunch of money at parts that compromise the original intent of the designers. I have built 35 of these guys and keep it mostly stock and enjoy them like I did in the 70's. I use stock springs, Delco or Gabriel shocks, IROC steering box, HD front sway bars, built BB or SB and I even like the original rubber bushings. These cars sat "low" from the factory with taller tires but most restos sit high due to either wrong suspension or after market parts. Just some thoughts from an Old Camaro Guy. My all original 69 with 55k miles sits 9" from the floor to the rocker. . . . check it out in the AIM with 225/70/14
The Camaro Guy is offline
TMI Sport R seats on a 68....height issue revisited Shan Interiors 58 Nov 9th, 19 06:02 AM
The proper way to correct steering on 1st Gen w/o going overboard Nick_R_23 Brakes, Suspension & Steering 21 Nov 7th, 18 08:31 PM
Confused about levelling the front ride height with Eibach springs Markus Brakes, Suspension & Steering 3 Feb 25th, 18 10:38 AM
need more rear ride height cblackmon Brakes, Suspension & Steering 8 Dec 23rd, 17 05:25 AM
Global West L2 ride height Grifter Brakes, Suspension & Steering 0 Nov 29th, 17 03:58 PM
