No Rear Brakes '67 Camaro - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 16th, 19, 02:42 PM Thread Starter
Andrew
Andrew69's Avatar
I pulled the drum brakes off of the 8.2" 10-bolt to transfer to a fresh 12-bolt rear. When removing I noted the brake shoes were not adjusted for solid contact with the drums. I also found the front to rear line was pinched flat at one point. Those two things made me believe the car's rear brakes were not functioning.
Now I have installed the rear brakes onto the 12-bolt rear and replaced the front to rear brake line. This morning when trying to bleed the rear lines we couldn't get any pressure. Multiple pumps yielded no pressure at the rear wheel cylinders. With the master cylinder cap removed, when you apply the brakes, the front reservoir fluid pushes up while the rear reservoir fluid doesn't move. This leads me to believe the master cylinder is bad, as in not pushing fluid to the rear brakes. The rear brake concerns are compounded.
What does the hive think?
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #2 of 10 (permalink) Old Apr 16th, 19, 06:16 PM
scblucam's Avatar
Re: No Rear Brakes '67 Camaro
Check the rubber line from the main to the tee in the rear. They can collapse and nothing goes through.
68 302 M20 - 85 IROC Z
scblucam is offline
post #3 of 10 (permalink) Old Apr 16th, 19, 06:25 PM
You will be assimilated
That is exactly what happened to me. I purchased new cylinders, axle lines, T-fittings and the flex hose was ultimately what fixed it. It was a bit difficult to break ( I mean brake) free, but I can stop now
1967 RS/SS Vert (non matching)
aggiegoalie is offline
post #4 of 10 (permalink) Old Apr 16th, 19, 06:46 PM
scblucam's Avatar
you will be assimilated
lol
scblucam is offline
post #5 of 10 (permalink) Old Apr 17th, 19, 07:15 AM
You can always break the hard line at the rubber hose and bleed/see if fluid is present.
If yes, then hose is hosed.
On shoe contact, an old trick is not dome any more - arc turning where the shoe is ground to the radius/diameter of the drum as this will give full contact.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
post #6 of 10 (permalink) Old Apr 17th, 19, 07:41 AM Thread Starter
Andrew
Andrew69's Avatar
My plans now are to replace the master cylinder and 9" booster with a repop Delco Moraine 11" booster and new master cylinder. While I am at it I'll also replace the rear flex line. This will involve bench bleeding and bleeding to all four corners but should fully resolve all concerns.
I'm with you on the arc turning and I doubt that service is now even available. I still need to adjust out the shoes but don't want to overdo it. Won't cycling the emergency brake multiple times turn the screw to optimal tightness? I don't yet have the emergency brake connected but plan to test this theory.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #7 of 10 (permalink) Old Apr 17th, 19, 09:30 AM
E-cable MIGHT work after being pulled 47 times, but I would use a brake spoon and adjust, a lot quicker.
Also, backing up and applying brakes adjusts brakes.
And a 9-inch diaphragm vice 11-inch diaphragm would allow removal of drvr side valve cover.
post #8 of 10 (permalink) Old Apr 17th, 19, 10:26 AM Thread Starter
Andrew
Andrew69's Avatar
Why is there always a gotcha! Didn't the factory utilize the 11" booster with the big block?
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #9 of 10 (permalink) Old Apr 17th, 19, 12:44 PM
keith
X-77 keith's Avatar
Adjust the brakes before replacing anything. They will not bleed if they are not adjusted.
X-77 keith
X-77 keith is offline
post #10 of 10 (permalink) Old Apr 24th, 19, 06:33 PM Thread Starter
Andrew
Andrew69's Avatar
I used the brake spoon and got the shoes closer to the drums. I replaced the rear flex line even though the one removed seemed to be clear. The booster and master cylinder are replaced. All are bled out and the brakes now work as they should. I'll soon reinstall the emergency brake cable which will further adjust out the rear drums.
Thanks for the help!
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
Brakes soft, brake rod location 67 Camaro Rls8836 Brakes, Suspension & Steering 3 Mar 16th, 19 05:23 AM
Rear pinion snubber 67 camaro Heavychevy67 Body Shop 3 Feb 10th, 19 04:55 PM
Is a 67 Firebird rear seat the same as 67 Camaro deluxe 68resto Interiors 2 Nov 14th, 18 08:32 PM
67 camaro - Rear end ID help opr8tions Transmission & Driveline 1 Apr 9th, 18 09:16 PM
69 Camaro Rear Brake Conversion with Mini Tub Kit Camaro1969 Brakes, Suspension & Steering 4 Dec 8th, 17 05:04 PM
