Brake Pedal linkage - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 18th, 19, 11:02 PM Thread Starter
Randy
Brake Pedal linkage
My 67 RS/SS had manual disc brakes. I am in the process of upgrading to something similar to the J50 A2 system shown in the FAIM. My Bracket Assembly has both a bumper and a switch that is activated when the brake pedal is against the bumper. Where in the manual is this switch shown? Secondly what does it do?
57s67RS/SS is offline
post #2 of 3 (permalink) Old Apr 19th, 19, 10:08 AM
Re: Brake Pedal linkage
It's the brake light switch. UPC12 B7
my 67' build thread:
allanjs is offline
post #3 of 3 (permalink) Old Apr 20th, 19, 06:57 PM
David Pozzi
davidpozzi's Avatar
You won't need the bumper for power brakes. the booster rod stops the pedal. You need a metal tab to contact the switch, the tab bolts to the upper "manual" hole in the pedal. the pedal sits lower on a power brake system because the pedal ratio is different and the power master cyl will reach full stroke with half the pedal travel.
My web page has some info on the topic: Brakes
davidpozzi is offline
Enhance Camaro's braking with Power Stop Z23 Brake Kit + CARiD Video carid CARiD.com 0 Dec 17th, 18 07:16 AM
Removal of Brake Booster alexander12m12 Camaro Tech 21 Nov 28th, 18 09:49 AM
Brake booster and pedal problem 69firebird461 Brakes, Suspension & Steering 9 Aug 31st, 18 01:05 PM
rear brake lines zboss86 Brakes, Suspension & Steering 11 May 6th, 18 12:40 PM
